By Kawiherder
By luckyyyyesther
Hey all!
By opnea
Recently picked up a 1991 Lt230e for repair. Compression is a little low Id say, around 80psi, I also have spark but the spark is odd . When cranking the spark is a constant arc. I’ve got it to sputter but never fully turn on. I believe the spark is my issue, being constant and not detonating at the right time. I’m not sure whether this issue is an electrical fault like some missing ground, a faulty cdi, or a timing issue. Any ideas where I should start?
By p5200
20240217_114429.mp4 -
By Traytonrowland
So, I bought the machine almost a year ago and have been chasing problems. I have replaced the battery, starter solenoid, spark plug, and the starter. Since having replaced those, it doesn't want to start. I checked the carb, and it was wet as well as the spark plug. And I've searched multiple forums and cannot find an answer. So, anything that helps is appreciated, thanks.
Similar Tagged Forum Content
- 1 reply
- 2,808 views
- 12 replies
- 9,162 views
- 0 replies
- 3,381 views
- 8 replies
- 2,562 views
- 4 replies
- 3,697 views
