In this video, Jonathan describes how he cleaned a Nikasil plated cylinder.
Aluminum cylinders are often coated with a harder material such as Nikasil (Nickel Silicon Carbide). Over time, the softer aluminum of the pistons can rub off onto the cylinder. When rebuilding the top-end, this should be cleaned off.
This can be done using hydrochloric acid which reacts with aluminum to produce hydrogen gas and aluminum chloride, which washed off with water. Since Nikasil is resistant to corrosion, it is undamaged and protects the cylinder during this process.
Here is the chemical reaction:
2 Al (s) + 6 HCl (aq) → 2 AlCl3 (aq) + 3 H2 (g)
Resurgence Small Engine Inc.
ATV, Snowmachine, Motorcycle, & Outdoor Power Equipment
Create an account
Register a new account
Sign in
Sign In Now
    • By Joeguy
      I been working on this thing for like 2 months now and it will not run right, is very smokey, and has a pretty loud tap that i think is in the bottom end. Not sure how much the parts are but i will put the time into it if they are pretty cheap. Im not very experienced but going off how the plug looks and the oil on top of the piston i am getting a whole lot of oil coming in from somewhere, not sure if it can come from the valves or if the rings are just shot, my cheap scope cant really see the walls of the cylinder too well.
      20241009_123850.mp4
    • By Ulfthednar
      Got others in the works.
      Been years since I really played with editing software and content creation. ATV+Gopro+Davinci.
      https://youtu.be/-JV-xEq9uW8
    • By Brian Emerson
      Hi Guys, this Quadmaster has an extremely loud bang after turning key off (from idle), scares the stock, dog and missus, any ideas on what to check.
      Thanks and regards,
      Brian
    • By huntindog
      TIA
    • By Sofaspud
