  • Join Today, It's Simple and FREE!
JacobSlabach
1997 Kawasaki Bayou 300 2x4 (klf300b) Runs Bad
Ok so when you rotate the motor and watch the cam spin  is there any point that the valve rocker is tight ? Like lo play ?
Share this post
Link to post
Is that spot where the rockers are tight anywhere near top dead center ?  I just find it so odd that there is a spot like that and it’s not top dead center.
Share this post
Link to post
ohhhh i see what youre driving at...maybe lol  I will check when I'm swapping out the shocks lol i was ripping at some land we own and broke a front shock on a jump 🤣
Share this post
Link to post
Lol we were just talking about jumping! You don’t learn do you? Lol nice work kid keep at it.  If you can’t break it then it’s no fun!
Share this post
Link to post
i broke mine trying to winch drag it over a rock in the snow and it pop'd that rubber drain plug (while running) and sounded like a man drowning on his own blood!!! does that count same as jumping and snappn' a shock :D
  • Haha 1
Share this post
Link to post
haha.. I'm definitely selling this one... doesnt do the two things I love best- jumping and popping wheelies😅
  • Sad 1
Share this post
Link to post
how many jumps n wheelies can you do with utility 2x4? heh
Edited by pokerl0w
Share this post
Link to post
....haha a lot with a honda or 2x4 polaris or yamaha.... the bayou just has a frame too long and too heavy for the power it puts down..no torque..:nah:
Edited by JacobSlabach
Share this post
Link to post
I do not mind the longer frame for wheelies myself. weight no..
wonder what the weight difference of the bayou vs polaris. how much could it be to prevent wheelies, jumps, and only snapping a shock I mean - that's the best thing to snap! that bayou is doing you right, that clicking is probably kisses you're neglectin :P
Share this post
Link to post
haha welll lets just say I cant wait to get rid of it and get my sportsman working:v_SPIN:
Share this post
Link to post
Nooooo thanks! I’m kinda backed up on bikes right now.  Three bikes to sell right now.  And after watching @06kfx440 ride his bike I have to get that Mojave I have sitting around doing nothing moving.   I have not rode a clutch bike in a while so im Itching.
Share this post
Link to post
You can ride mine any time you want Frank.
  • Thanks 1
Share this post
Link to post
Had a guy come and drop his bayou off for me to service.  While he was here he asked about my bayou.  Went to start it and it floods out like it did before (last issue I posted about it before the broken shock)  pissed me off pretty bad cause yesterday and the day before it started no problem.....now the guy is probably like what the hecks wrong with this kid- his bike wont even run....though he was a lot nicer than that about it...  so all in all I want to resolve this issue now before I get his bike working so that he could test ride mine when he picks his up...  This is either a sp issue or a ignition coil issue I'm thinking...  Its the 3rd brand new sp the bike has blown since I rebuilt... What do yall think?
Share this post
Link to post
Your float in the bowl may be getting a little jammed up allowing excess fuel to get into the engin/head thus flooding out the sp.  The float has a pivot point where it mounts to the carburetor. Either it’s getting stuck on the way up or the pin that the float pushes up is getting stuck. I know the over flow would show signs of fuel dumping out but it may not be so severe that it’s showing.
  Also one more thing. The top of that pin has a rubber tip on it.  Take a look and maybe replace the pin if needed. Check that the pivot point on the float looks straight and nothing is restricting its travel.
Share this post
Link to post
Curious. What's your voltage at in the sp boot, coil and stator
Share this post
Link to post
That is a great question.   It could be that your spark is breaking down at some point and soaking the plug because no or poor spark. Definitely a good possibility.    @06kfx440 👍
Share this post
Link to post
I'll try to get it looked at...  focusing on my sportsman and the 220 I'm working on rn
Share this post
Link to post
Btw, bayou is for officially for sale for $800 first come first serve lol  if you read this thread, you know all of it's history as far as I've owned it...  massage me privately if interested.
I'm thinking the ignition coil is going bad maybe causing a weak spark and that was also causing it to run rich (and after riding the 220, I noticed its a little more sluggish is throwing the power down)
Share this post
Link to post
I will see if I can check the voltage at the boot.  How is the best way to do that?  Just hook positive of a multimeter to the boot and the other end on the frame?
Share this post
Link to post
  • Similar Topics
    • By Andrew520
      Got a good deal on an 89 bayou 300. Couple questions. First is in the picture I have posted. Note the two wires at the bottom of the pic (white and black/yellow). They were not hooked up to anything and Im not sure if they are supposed to go to the battery or somewhere else and what they are for.
      Second question is I had the carb apart for a cleaning. The vaccum operated slide has a spring under the cap with a plastic clip that goes inside the spring. Is there a proper location inside the spring for that clip. Right now it is just below half way inside the spring.
      It runs alright but keeps fouling the plug. Pulled the plug off, cleaned it and dried it off and it starts back up but not sure how long before itll do it again, last time it was about 20 minutes of riding and it bogged out and wouldnt start.
    • By Kelby 746
      I have a 1987-89 (not sure on the year) Kawasaki bayou 300 that has electrical issues, I have replaced the entire harness with a proven good/used one, new CDI box, and two brand new coils, problem is that it tests no charge at the pickup coil, so I replaced and tested again with a so called good one that had been salvaged out of a blown up 220/250 (not sure which, the left side cover is smaller than my 300) in Missouri. It has a proven good OEM stator. I am trying to avoid buying a new start and pickup coil because it is so expensive so if anyone has a suggestion please let me know.
    • By JacobSlabach
      i know this isnt an atv but same type of thing.  I have a riding mower im fixing and selling for my aunt and it has a dead battery.  i jumped it off my atv and when i turn the key nothing at all happens.  i tried jumping the relay still nothing.  this is with the seat down.  you wouldnt think this mower would have issues as its a top-of-the-line brand and almost brand new (aunt found it for a good price, still got tits on tires, just sat for a couple months in a mechanic shop
  • Similar Tagged Content
    • By lizalee
      i bought a kwasaki bayou 220 and the person i got it from lost the key so they wired it to bypass the key start to use the pull rope but the wires got unhooked some how now i dont have a clue how to wire it back up to pull rope start. does any1 have a pic of the wires or help me im a newby
    • By Monika Novakov
      1988 Kawasaki 220 Bayou trying to remove generator/ starter 1way clutch cover to be able to replace 1way clutch. All bolts are removed case cover is dripping what oil that remains...but I can't get the cover to come off..what am I missing? Thx in advance.
    • By frostyflammable
      Hello all, wanted to sign up for this site as I am sure I will have lots of questions soon. One of my coworkers has given me a free Bayou 220 that does not run, I was told it needs a new wiring harness, however I cannot confirm any of that yet.
      Next weekend I am going to drive up to the place and pick it up and get some hands on but right now trying to find some service manuals so that I can trace and find out what is going on. My plan is if I can get it to run to do a full restoration and use it to putt around the trails around my house.
      I have some experience with small engines, currently have six mini bikes and a buggy with a GY6 motor that I brought back to life and I am hoping I can do that same with this. Really hoping the Bayou has good compression and it's only a electrical problem.
      In the mean time I am going to be reading this forum to learn as much as I can and hopefully find a service manual. I have attached the only pic I have of it so far.
      Thanks!
      Daniel
    • By 220Bayou
      What weight gear oil for this machine?
      80w90?
    • By Squirrel
      So I bought a Bayou 220 as me 'Black Friday' score, and was informed it has carb issues..
      A little history from the previous owner: they suspected the carb was bad as it was 'running like crap' so they did a rebuid kit on it. Didn't fix issue so they took it to a shop where the tech installed an aftermarket(?) carb, but had to modify the throttle cable to get it to work. Quad ran great at 1/4 throttle, but anything above that and the throttle would stick and the machine would run like garbage again.
      What I know and think: I hear carb issues are common and fairly easy to fix. Also, I think they used the 'universal' rebuild kit that claims '88-'11, but the jets and such were different from '00-'03 (gaskets, etc. appear to be the same) so their original attempt was a good idea, just not good enough.
      They did give me the original carburetor with the 4-wheeler, but it has the wrong internals. I'm thinking if I can get the right jets, springs, etc for the rebuild, I should be able to get this thing running right. Of course, I still need to charge the battery back up, change all the fluids, replace fuel lines, plug and wire.. ya know, the basics for a machine that's been sitting for roughly 9 months. lol
