viper0906
2001 Kawasaki Bayou 220 Engine Locked Up
That primary is gone! The ruts wil prob show that its within spec maybe because the high points in the ruts.  It’s not supposed to look like that.  It has to be replaced.
Share this post
Link to post
haha thats prolly what my bayou clutch looked like- had to adjust it wayyy tight to run and not slip- I couldn't have done anything about it tho cause any more money I sunk into it was money I lost...
Share this post
Link to post
Prob best thing you did was move that bike along to a new owner @JacobSlabach.  That clutch housing on this bike is in bad shape.  When that clutch looks like that It’s basically the same thing as letting your brake pads on a car run down to the metal.  It destroys the rotor and metal shavings get everywhere.  That primary housing should have some meat on the inside for the clutch to grab.  The secondary is prob ok but the metallic shavings need to be cleaned out.
Share this post
Link to post
@Frank Angerano So pulled the secondary down and found also two things.  First is the new clutches I put in are right at the service limit.  These were after market clutch disc bought on amazon.  The next thing is the question of the two washers on the secondary clutch.  I have information in the clymer manual that does not match each other.  Which one goes on first? The special note at the top of page 212 says the outer washer 20 is thinner than the inner washer 17.
Then the diagram on 212 calls 20 the inner washer and 17 the inner washer.  but pictures on 213 figure 54 and 57 seem to go with thin first then thick?  Does anyone know which way is correct?
Share this post
Link to post
  • Similar Topics
    • By John Brucato
      Hi all new to the sight haven a problem with my 1988 kawasaki bayou 220 it ran then just died when out one day get gas but no spark any info will help I'm new to the ATV got it used and ran like a champ but don't know where to start when it comes to this
    • By Bryson Bailey
      Hey I have a Kawasaki buyou I put a new carburetor on it and a brand new spark plug coil and still firing up could you know what my problem is anyone please
    • By Arizona
      Back again with another headache, maybe you guys can help me out.
      Picked up a 87 Bayou 300 not running of course, all stator wires melted
      on the motor and also no spark. I checked the pick up coil ohmed out good.
      traced the wires and led to no cdi box, yes missing. So ordered it and while waited
      fixed the stator wires, had to wire direct to harness. Get the cdi installed and after a lot
      of other things started it up. Battery dead so used a batt charger to start it. Now when i shut
      off the charger the motor died. So i check charging voltage...nada. I see voltage regulator is
      old and catalist leaking so i replaced it. Same thing no charge. I check stator and no voltage
      with it unpluged from harness while running. Soooooo i replace stator. Now Stator wires have
      23v and up to over 50v at higher rpms. So i know its charging now. Connect everything back up and
      no charge voltage at battery! Still dies when i shut off charger. All 3 yellow stator wires have good voltage, checked
      harness from stator to regulator and is good. The white wire has battery voltage at regulator, the brown wire has battery
      voltage at regulator when key on. The Black/yellow stripe has good ground. I get 3 volts at battery when i shut off charger.
      If i connect old regulator i get 7 volts when i shut off charger. Do i have a defective new regulator? Im stumped. when i
      figure this one out i have a big wiring problem on another one ill let you in on.  Az
    • By Ross
      http://www.off-road.com/atv/tech/2003-kawasaki-bayou-300-atv-29516.html
      I can't find the serial number or a specific manual for this atv. It sounds like the same one in the link above. It says Kawasaki Bayou 300 Dual Mode Differential. And it has a handle lever attachment for shifting, fuel gauge, and a small storage compartment. Can anyone find me a manual? Pictures attached
    • By 1911Neil
      I had a quad fall in my lap a couple weeks ago. The only things I knew about it was it was a Kawasaki Bayou 220, was in pretty rough shape and was free. I couldn't say no to a fun little project. I've been looking a different ATV forums gathering quite a bit of info and decided this was the one I wanted to join.
      Thanks to this forum, I found the VIN under about an inch of mud and cross referenced it to be a '98. It had been sitting outside for at least 5 years and was told it ran when parked, but had no brakes. Squirrels or mice had been chewing on the handlebar controls and it's generally just kind of beat up.
      So far, I've gone through the carb (not near as bad as I expected), freed up the brakes (will probably need new cables), replaced the spark plug, air filter, petcock and put a new battery in it.
      The gas tank had been empty and looked clean so I put some fresh gas in it and tried to crank it today. I got a neutral light, but the starter button did nothing. I tried pull-starting it and it wouldn't fire. I checked the plug and wasn't getting a spark. I started digging and found some potential issues and some definite problems.
      I have a wiring diagram I found on here but it's just a picture or scan out of a book and hard to read. I don't see a reference to a black/yellow wire, which is my first problem.
      First, it that a factory crimp? One of those wired looks like it goes to the connector in the 2nd pic. Is that just a spade lug type connector? I pulled on it with some needle nose pliers but it didn't seem to want to come off. In the 3rd pic, should there be a fourth wire?
      I've read through and bookmarked the threads Andrew Baker and Arizona have going but I figured I needed to start with these obvious issues first. I have lots of pictures, so if there is something else you want to see, just ask. If I don't already have a pic, I'll take one.
  • Similar Tagged Content
    • By Bryson Bailey
    • By 1911Neil
    • By Mike Strayhorn
      last year I bought led lights when I was riding my 4 wheeler the lights started getting dim shut off
      now my 4 wheeler will not start the battery is hot everything is dead I checked the fuse and its good
      would there be another fuse I am missing I'm took the led bulbs out and replaced them with the ones that was in there
      wonder what meh problem is
    • By EoNe Frost Vortex
      Hello i was wondering if someone could help me out iv recently got a Kawasaki klf 220 it needed big end bearing changing so i rebuilt the engine and the bike has compression starts first time every time but after i have been riding for about 10 minutes oil starts to leak from the head just below the exhaust so i replaced the gasket still done it so i took it to a shop he done the same and it is still doing it any information would be great thank you
    • By oxidized_black
      1988-2002 Kawasaki Bayou 220 Service Manual
      Engine
      Chassis
      Size
      Basics
      Features
