  • Join Today, It's Simple and FREE!
JacobSlabach
2004 Polaris Sportsman 500 Reversed Terminals On Battery
ha good one.  I'm thinking the flooding is from bypassing the pump-  It makes since that the gas might be pushing on the needle too hard forcing its way into the carb bowl, bubbling up through the carb and into the intake or airbox(whichever is lowest)  You have to give it to polaris though- only problem its had that I didnt cause so far is the head gasket.  And it still rode perfect once I got it going today-  rode out on the road with a friend and had it pegged for a couple miles on a back country road...  Tons of fun!  wish I coulda video'd it with my go pro-  probably topping 50 most of the time when not sliding around curves- bike didnt give a hiccup and almost popped a wheelie at one point...
Share this post
Link to post
That’s great.  You should invest in a clip for your phone that straps to your chest.
Share this post
Link to post
one problem.... parents wont let me get a smartphone 😭
  • Sad 1
Share this post
Link to post
yep got a laptop.  Ok so heres whats going on:
  1. Fuel pump hooked back up- no more flooding and it appears to be working
  2. It no longer smokes...at all
  3. I took the 'snorkel' off the top of the airbox lid and adjusted the carb needle up (richer) to let more fuel and air into the engine
  4. The radiator has drained the antifreeze twice so far
Heres my theory:  The 'smoke' was just condensation because it was 40 or below when it was doing that, now that it quit, it over 50...  The antifreeze disappearing:  I guess the radiator was drained or leaks because the bike was sitting for a long time before I got it.  I'm thinking as the radiator runs, it is sucking antifreeze into itself.  I think this because I noticed that there were bubbles coming up from the hose in the antifreeze while the engine was running.  Any input would be great!  If this is what I think it is, the bike is ready to sell as soon as I clean it up....👍
I will say to all those out there with carbureted sportsmans:  If you want more power, Take the snorkel off the airbox lid and adjust the carb needle clip down one notch-  My sportsman is scary responsive now, it roars and also spins the rear tires if pegged.  Before there was about a half-second delay in the throttle to rear end, now they seem to be directly connected- and my belt is shot too
Share this post
Link to post
The cooling system  should be full  of anti-freeze /water  mix .. there  is an expansion tank  where you  fill the system..  When  the  system  is cold and full  the level  should be at the full  mark  on the expansion tank.. As it  heats up  the  coolant expands and  some is forced into the expansion  tank..  Shut  down and cool off and it  is drawn  back into the radiator..  If  the expansion tank  is too  low  or the  radiator  has been  opened  cold and air allowed in either  by  drawing fro the  too low tank  on cooling , or by opening the rad ,  air will  bubble into the expansion tank  on warming up.  If all  levels are right , there  should be no  air  bubbling into  the expansion tank  after all  the air allowed into the radiator  has  been  released after  one  or two  heat and  cool cycles .. If  bubbling still occurs  after everything is  normal  and cycled a few times , you have a leak  in the system.  Most likely  a head gasket leak.
The  "smoke"  or steam  in the exhaust  is  normal  in cold weather  , especially if it  is wel l below  the temperatures where you see your breath ..  One  on the products of fuel  burning is water vapor. It condenses  in the muffler  when the engine  cools  and is  boiled off as steam  when it heats up. .  If there is a  lot , it could mean  a slightly leaking  head  gasket ..  The main indication of that  is the level  in the expansion tank  going  down  below the add  fairly  quickly  and constant bubbling into the expansion tank.
Share this post
Link to post
ok so I here you saying it could be both a head gasket and condensation?  I did happen to look in the cap of the radiator when I had the bike apart before I got it running and I didnt see anything in it-  I'm thinking its just slowly refilling itself?  Anything I need to do about it?  Fill from the radiator maybe?  And the steam seems like condensations to me- only does it when (like you said) its cold outside and I can see my breath.  So when I turn the engine on from cold, there is a pause (muffler heating up probably).  Then it gushes white for about a minute, then quits for the rest of the ride- till the engine gets cold again.  And doesnt do this when above 40ish
Share this post
Link to post
Fill  the radiator with  anti-freeze mix and cap it . Afterwards  top up  at the expansion tank. Any air  left in the system  after you've filled the radiator  will  be expelled as the motor  heats up.  Once the radiator  is full  and all  air  from  having opened it to  fill  there should be no  more bubbles coming from the radiator to the expansion tank.  If it continues to  bubble  and  level  goes down  you have a leaky  head gasket.  the  steam in the exhaust  depends on the moisture amount in it ..  In very cold weather it  may  steam  for  a minute or two  before clearing, but if you're  getting a  lot and you see the bubbling and  fluid loss, then  it's  most likely  a  small leak in the head gasket.
Share this post
Link to post
update on this bike:  Radiator finally filled up, fuel pump went out (I let dirt get into it when I ran it gravity-fed and it clogged it up or something..)  ordered a new pump ($10).  it still smokes condensation when its cold out, but no sweet smell and no smoke when its about 50.  overall I love this bike, want to sell to get a newer/bigger sportsman.
I still cant get over that it will burn out on asphalt even with a burnt up clutch that doesnt engage till half throttle.... just too much power in this bike.
Share this post
Link to post
You are out of your mind kiddo! Burnouts on asphalt ???? Try not to kill it before you sell it!
Share this post
Link to post
I'm tellin you man- these bikes got a lot of horse torques:jiggy:
Share this post
Link to post
so I'm trying to figure out if I want to keep this bike or sell it.  So I want an 850 or 1000cc for playing around and work and trail riding and stuff...  but I kinda want to keep this bike and make it into a mud bike...like put bigger wheels on it, snorkel and relocate the radiator...that way if I sink it and kill it, its 2k gone rather than 8k (for a newer efi model)  Yoiu guys think its worth it?  Is this a good bike for modding it into a mud machine?  If so, what necessary and whats not for the mud?
the other option is to sell it...  I know I can get at least 2500 out of it right now..  I have 2k in it currently.
Share this post
Link to post
comment on what you guys think i should do with this bike...  my biggest concern rn is how big can I go with my wheels?  I was thinking of a square setup (front tires are as wide as the rear) with 1in wheel spacers.  I have a 2in lift on the bike, but I concerned that 28in are gonna scrub the fenders...?
Share this post
Link to post
To be sure about rubbing your going to have to collapse the suspension as much as you can then take a measurement form the center of the hub to the fender where the first contact would be. Then measure your potential wheel from center of wheel to edge of tire.
Maybe a good ratchet strap or a come along to collapse the suspension to mimic how far the suspension will travel but be careful.
Share this post
Link to post
yes was checking that.  looks like the closest fender-to-wheel distance is from the the foot rest to the wheel.  plenty of room above the front wheels, just not behind them.  I was wondering about front a-arms that relocate the wheels forward?
Share this post
Link to post
so yea i decided to keep it for a mud machine.  Looking to snorkel it eventually- maybe something like this?  Not looking to get the snorkels really high, just want them higher than they are now.
eh sorry those are tiny pics :daydreaming:
and the wheels something like this
Share this post
Link to post
so i guess the main things I'm going to be working on
  1. Need a-arms that relocate the front wheels forward
  2. need a snorkel
  3. need a radiator relocate...???
not sure about the radiator relocate- I think the main thing would be how low down the coolant reservoir is and it has a breath hole in the top...
was looking at some tires like these:
Share this post
Link to post
and i really really like these but they are 200 each just for the tire- the above pics were off CL for 400 (the blue rimmed set) and 900 (black rimmed set)
Share this post
Link to post
  • Similar Topics
    • By Benton Williams
      Guy i bought it from said it is 4wd just needed a few parts. not sure which ones. Help.
    • By kgard
      Hi all, I bought a 2018 used 450 for my wife. She is having trouble with some of the real rocky trails close to our home. Her arms give out in an hour or two so I was thinking of adding power steering . Is this possible ? Anyone done this ?
      With this cold snap, I noticed yesterday that the battery on my grizzly was a little weak. even clicked a few times before I got it to start. I'm thinking of picking up a batter tender/ trickle charger so was wondering what people use to keep their ATV battery charged up. I was looking at these on amazon. They both have good reviews.
      or this one
      Kind of like this one because if the accessory plug
    • By FlyingJBIRD
      I've bought a used 2007 Polaris Phoenix 200... it's in pretty good shape... but after it starts, warms up, a few minutes of my son riding around yard it will die... it refuses to start back until the next day, then same thing again... I've seen this is a problem but haven't found any real answers... my son is driving me crazy to get him back riding... any help is greatly appreciated...
    • By Chad Hjortshoj
      Hey, working on my gf's lil dvx250 which needed the carb cleaned.  Like an idiot I removed the bracket that holds the choke lever on and the spring that was behind it that I hadn't seen popped off. Anyone have a clue how it goes back on? The manual pics dont show it and I had no luck on YouTube! Thanks!
  • Similar Tagged Content
    • By Kevin Ciccone
      Hey, how's it going?
      I'm a new member looking to get some advice before I go to check out a '14 Sportsman 800.  I wanted to get input from you guys that have experience with Polaris machines. I've been riding my whole life, dirt bikes and atvs... Honda, Suzuki, Yamaha, but never Polaris.  I'm looking for advice on what I should be looking for, any common issues, really any general advice.  I couldn't find many reviews of the Sportsman 800 online, so and general reviews on quality/reliability would be great too.
      A little info on the machine.
      -2014 800 EFI
      -640 miles, 77hrs.
      -Winch
      -Asking price is $5500
      Couple add ons: (nothing major)
      -Aftermarket wheels with Maxxis tires
      -Front and rear brush bumpers
      -LED lights
      Probably going to see it in the next couple days. I'll make sure to check out all the basics... Fluids, front end, tires, suspension etc.  Plus anything else you guys recommend.
      Thanks for any advice on advance!
    • By Jeff011366
      Hello,
        Over the years I have always used a friends machine, and only ride a few times a year. Last week I purchased a 2002 Polaris Sportsman 700. The front diff needs a rebuild, the axles are very loose where they go into diff. My question is, both front wheels rotate forward by hand, but do not rotate the opposite direction. Is this "NORMAL OPERATION" I plan on rebuilding the hubs at the same time as the diff.....
        My question about the rear diff, it rolls as if the machine has a total POSI rear axle...……. I lifted the front end off the garage floor with overhead hoist, as I moved it sideways the rear tires skidded rather than rotate. Both would roll forward easy, but not go in a circle. When I drove the machine in the garage making a tight turn I could feel the binding and skidding of rear tires....  Even if the switch was in 4 wheel drive, when it's hanging in te air the ignition is off...….. with the machine in 2 wheel drive mode, is that HONESTLY 1 wheel drive to allow turning without tearing up the lawn? then it locks the rear axle once it's put into 4 wheel drive? I'm guessing the rear diff needs a rebuild also because there is something "BALLED UP" internally locking the rear wheels together?
        It's a old machine that was not maintained, I thought the wheels were all rusted, but it was 17 years off baked on red clay. Just wanting to make it a reliable machine. I have great mechanical ability, just lacking a little knowledge of what is suppose to be "NORMAL OPERATING STANDARDS"
      Thank you in advance for sharing your knowledge.
      Jeff
    • By 98whitelightnin
      Just got a 2019 570 a few weeks ago, haven’t got much seat time yet but I’m loving it! I’m not new to riding but new to Polaris. I’ve had a few 4wheeler’s over the years, including a Yamaha kodiak 450 and later a Honda rancher 420.
    • By Dave2012
      Hey guys, new to the page from Australia. Just wanna know if  anyone has had an alternator charging prob if using an auxillary piece of equipment eg spray unit. New battery, and cant seem to catch the alternator playing up, reads all good on outlet power.Just doesn't keep up the charge only when using spary unit, and headlights are off.....
    • By colin james
      View File 2005 Polaris Predator 50/90 Sportsman 90 Service Manual
      This is the factory service manual for the 2005 predator 50cc and 90cc, Sportsman 90cc. Download all the chapters for the complete manual or just the sections you need.
      Submitter colin james Submitted 04/06/2019 Category Polaris ATV
