1993 Kawasaki Bayou 300c 4x4 Tie Rod and Shifting Issues
pokerl0w
but yea with the lug nuts, make sure to torque them down because you wouldn't really notice a lose wheel unless you're going fast and that could definitely cause rubbing.  And the stop switch...I done it too- tried to start it with the stop switch off..  after that, I never used the stop switch to turn it off- just the key..maybe that would help to prevent it from happening again....haha
well 💩 I found out why it was still leaking oil even with the tap plug. Not sure if I did this tapping or at the start when I stripped.
guess I am done, yeah? I can not go larger tap, it will most likely crumble the rest. I'm going to try to re-use the same plug with loctite and new crush washer... but this means it will not hold and can it even be repaired?
Ugh thats bad.   Jb weld will work great though.  Use the tap plug.  Drain the oil lay the bike on the side so no oil is in the area of the threads when installing the plug back in. Clean it a little with a carb cleaner and dry It good so no oil is in the area.   That’s why you have to lay it on the side and let it sit like that for a few min.
The only other thing to do it bring it to a weld shop and have a guy that’s know heli arc alum welding and weld the tap plug in place.
I may not have explained how I would apply the jb weld but I would putt a little around the threads and send it in and ASAP once it’s in I would add some in the area where the chunk is missing and a small bead around the entire  plug where it meets the engine to be safe. It has to be clean though and even if you want rough the area up with a little sand paper.
  • Thanks 1
guess I'll try the jb weld first.. and then turn focus on the gears. hopefully it just needs adjustment, but my concern is that drip from the bottom/back of the motor where I think the clutches are. I was thinking, if anyone knew what to test to know if I am in deeper and I would wait to weld since I probably have to pull the engine. Maybe it is just a clutch adjustment and needs a new gasket. maybe i'll get lucky
  • Admin changed the title to 1993 Kawasaki Bayou 300c 4x4 Tie Rod and Shifting Issues
to be clear, both are "tap plugs"? one was self-threading the other had the piggyback. if I use the one with piggyback, it is 14mm x 2.00 and the self-tap is 12mm x 1.75 - I am very much concerned that the larger piggyback will split more. When I look close there is also a tiny crack (on the outside) at the end of where the chunk cracked off..
and for laying down.. guess that means also need to siphon the gas before I tip. anything else might leak? fuel left in hoses? never tipped one. maybe I can use a tree branch and pulley to lift it straight back/front? would I gain anything?
I also think I should remove plastic before I tip. lots of cracks in this gem. however if I pulley, I could leave them on. leave it dangling all night and scare neighbors that have smaller atvs
Edited by pokerl0w
forgot tap n crack stuff
The piggy back will allow you to drain the oil later using the small plug.   But you could go back to the original one of its a snug fit.   And clean the crack good and sand it up sand it up good so the jb weld has some grooves to get into.   I would prob drain the gas out but you don't have to flip it over just tip it sideways and block up the side of the bike so it the remaining oil goes elsewhere and not in the area of the drain plug during the repair.   If that holds you can always buy a small hand pump and pump most of the oil out of the engine through the oil fill plug. It’s a little unorthodox but  It’s a solution to a big problem.
On 1/28/2019 at 7:30 PM, pokerl0w said:
well I just used loctite, rubber crush and wanted to show ya'll the gears slipping first. I am about done with this bike.
I need to move the gopro to the front, clearly!! but I was in a rush....
btw, was jw, is your bike manual or semi manual?  Mine is foot shift but no clutch to pull.  Easier in some ways and harder in others to drive...
semi auto. last bikes I rode, I do not think they had auto's. I am used to the left handlebar clutch.
But, I really do not think it is my foot. because it will also slip out of 1st gear into neutral and it wasn't me, I swear! :)
  • Confused 1
and about the shifting issue...  have you adjusted the clutch?  I adjusted mine out and it started slipping under load untill I adjusted it back in.  best way to learn how to do that is to go to 👇 , enter you model, and look at the owner's (not service- you spend a week looking for it) manual and and you should find directions to adjusting the clutch
My Kawasaki | Save Favorite Vehicle Info, Quick Links, Dealer & More
  • Thanks 1
1 hour ago, JacobSlabach said:
did you use the akaso to film that video you took?
yes but not of the rubber oil plug install heh
ty for this. I will get to it soon. right now I'm riggin' a plow to see if I can move more vs with front frame heh
well I'm wrong. soon as the oil gets really hot n thin, it appears to leak. much much less than before but, guess that's why most everyone stayed quiet when I got excited that I thought it was working heh
it's good enough for now though, going to play in the 3' we got and 1' more coming over the weekend HOT DAMN!
    • By BruceG
    • By mehim
      Hi everyone.
    • By hardcastle
    • By Drillbit
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
