What is this?
By hardcastle
By Tuzz
By CaptJim
Hello guys, I hope I am not invading your space, but as you can see the current state of my project here it's not but about 50% ATV. I am hoping that some one here can point me to a wiring schematic that I can reference since the "Complete wiring harness" i purchased from Amazon did not include a diagram of any kind.
The ones that I am finding on line vary greatly but none show the connections for the separate 5 wire connector coming from the motor.
Can someone tell me where these wires go?
Thanks in advance for all help!
By Whiterabbit
3500lb, synthetic rope lead and everything needed to install for........................................ $89 bucks! I'm installing one on my '01 Bombardier Quest and it looks like a legit buy. If you have a RK nearby & you need a winch you might want to swing by before they disappear.
By 86096
I have recently acquired a 1985 Suzuki lt230ge quadrunner. It has an automatic clutch. How do you ride it. do I select a gear and then give it gas and it will go? What about downshifting? I don't want to jump on it and go and risk busting something on this old rig. Any advice would be appreciated. Thanks in advance!!!
