JacobSlabach
Yamaha Big Bear 350 carb problem
owner gave me permission to dig in.  Head is off.  Inside looks exactly like the bayou.  I'm thinking rings, valves, and a gasket set?  Should I replace the cylinder and piston also or just rings?  Trying to do it as cheaply as possible for this owner.  But if its not a good idea just do rings and valves, I'll get the whole sha-bang
Share this post
Link to post
Inspect the cylinder walls. Look for scratches up and down as well as cross hatching. If nothing deep comes up then go ahead and get a ring kit. If the piston is okay then just clean it up.
Share this post
Link to post
ok.  how do you clean the piston, and also the head?  Its got black build-up and I'm worrying about the new valves sealing correctly.  I tried carb cleaner on the bayou with no effect... maybe oven cleaner?  I herd that stuff will cut through some baked on crap..  Maybe I could try it on another piston first (I still have the old bayou piston with crud on it)
Share this post
Link to post
Try a soft wire brush. Nothing to crazy because you don't want to scratch the metal. I've heard simple green works wonders. Also you can try this stuff called awesome. You can get it from dollar general
Share this post
Link to post
The cylinder should be honed pit with a honing tool. I’ve attached a pic for you.  The pastor can be cleaned with starting fluid.   Def put a new set of rings in as well.
That honer goes into a drill and you go up and down the cylinder nice and easy at a slow speed.
Share this post
Link to post
Oh shit Frank. I didn't even know those were made. Can you bore with those too?
Share this post
Link to post
btw, thanks to quad crazy for making this forum easy to use!  my bike's derailleur hanger broke and I was trying to ask for help because I couldnt find the part online....  first the forum wouldnt let me post a pic till I had 10 posts (whats the purpose of that????)  then it wouldnt let me post more than 5 posts (and I was being as helpful as I could) in 24 hours...  it's like they are trying to make it as hard as possible to use their forum:aargh:...  THANK YOU to quad crazy for an easy-to-use forum!!
Share this post
Link to post
getting parts in- I ordered a valve compressor but it hasnt come in yet...  So I have new valves, a top end seal kit, new rings, piston, and wrist pin.  I have the honer too which I will use on the cylinder (it does have some minor scratching from the rings)
Share this post
Link to post
Sounds great just don’t go crazy on the cylinder.   A few passes is all it takes.  On another note the valve springs, when you put the retainer clip in to hold the valve make sure it’s in right.   They fly off and it’s gone!
Share this post
Link to post
update:  Rebuilt the bike with:
New piston
New rings
New top end gasket kit
New valves
Honed cylinder.
Compression rose from 60psi to 120psi
Runs great and a lot stronger.  Owner pleased.  I guess this is my first successful rebuild lol- I think I was losing compression again with the last one because I didnt replace the valves or hone the cylinder.
Share this post
Link to post
oh shoot.  I didnt take any because I knew what I was doing this time.  apologies to the forum!  Will take pics of the warrior as I get to it.
Share this post
Link to post
It’s always good to post pics for the forum.  A picture is worth a thousand words. Plus you should be proud of your work! The next guy with the same machine with the same problem will have something to look at down the road.
Share this post
Link to post
  • Similar Topics
    • By stuman6669
      my buddys 02? warrior cuts out as soon as you give it throttle. it stays running, but it missfires and pops through the exhaust. it returns to idle and idles fine. the timing looks ok and we have swapped the carb with no change.its been sitting a while waiting on carrier rebuild, it ran fine before that. any ideas?
    • By Bryson Bailey
      Hey I have a Kawasaki buyou I put a new carburetor on it and a brand new spark plug coil and still firing up could you know what my problem is anyone please
    • By oxidized_black
      View File 1988-2002 Kawasaki Bayou 220 Service Manual
      Engine
      Chassis
      Size
      Basics
      Features
    • By Trent Finnessey
    • By WIJBIRD
      Good morning!
      I have a 1999 Yamaha Big Bear 350 4X4 and I need to rebuild the carb. I have the dual-cable throttle model and I'm having a terrible time finding the correct kit for it. I'm not opposed to replacing it, but the only ones I'm seeing do not have the dual cable throttle system. Any help would be greatly appreciated.
      Thanks,
      Jay in WI
      P.S. I can send pictures if necessary.
