By DarkRider
By huntindog
TIA
By dvs1961
By Whiterabbit
3500lb, synthetic rope lead and everything needed to install for........................................ $89 bucks! I'm installing one on my '01 Bombardier Quest and it looks like a legit buy. If you have a RK nearby & you need a winch you might want to swing by before they disappear.
By Angstromm
2005 Suzuki KingQuad 700 4X4 LT-A700X
A bundle of wires taped together shorted and melted tape. After removing tape, the wires fell apart and there was no way to determine how wires connected. This is on the left side of the ATV (see attached pic).
None of the wires run to ground. None test for volts with key on or when ATV is running.
There are 4 wires that go into 3 wires.
4 wires come in from above – yellow/green stripe, white/brown stripe, green, brown.
3 wires are below – all are yellow w/o stripes & and bundled into chase with a blue & a green wire that pass through (see attached pic). The 3 yellows appear to come from generator.
ATV only runs off battery now. There is no charge back to battery and ATV dies upon disconnecting battery (with RPMs up). All fuses are intact.
It would appear that any wire can connect to the yellow wires, so no worries there. But the extra/4th upper wire needs to be connected or bundled with one of its mates and I have no idea which goes to which.
Any help greatly appreciated.
