  • Join Today, It's Simple and FREE!
Just about 2-3 days ago my Can-am Rally wont start. I didn't run it though any water or mud. The power goes on but once i press the start button all i hear is a clank:aargh:. I checked the battery and it is fine. If anyone has any idea about wat to check please tell me.
Share this post
Link to post
You could always get a voltage meter and start at the battery and work your way through the electrical system and see where it stops. Time consuming but it will pin point your problem.
Share this post
Link to post
I don't think it will be the spark plug. The motor is not turning at all correct? It would have to be something in the starter or a relay somewhere.
Share this post
Link to post
Sounds to me like you may have a bad starter or a connection problem at the starter. You can try tapping the starter a few times with a small hammer to see if get a reaction. Similar to a car starter, you may have worn brushes or a low spot the starter has stoped on.
Share this post
Link to post
Also check the fuses. My Ozark done the same thing. There is a solinoid that clicks like a bad starter if I blow a fuse.
Share this post
Link to post
I'm with Buck Billy sounds like a bad connection or bad starter.
Share this post
Link to post
i tried it, it was good i saw a little improvement but nothing. The fuse was fine also. So im going to take it to the dealer and get it fixed. thanks for the input.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Tagged Content
    • By mmgood
      Hey people
      Question for all, just picked a 1986 bayou 300 thinking of going synthetic any thoughts ?
    • By Arctic Snowdog
      Hi Guys,
      I have a small Sled Dog business and I train up to 14 Huskies pulling a Yamaha Grizzly 550, that is quite a lot of Horse (Dog) power. Sometimes in order to make the ride smoother for Dogs and us we ride in Neutral but on a few occasions I have noticed that the right hand (front) brake seems to loose pressure and does not brake at all. Is there a particular reason for this ? Is it a fault or is it something to do with us riding in neutral, I only use the ATV in this way a few months a year before the snow comes but I am sure I recall the same thing happening last season.
      Any ideas would be greatly appreciated because I am a far way from being a mechanic.....
      Have a super day and thank you all.
      Craig
      Lapland
    • By Wiktorix Gameplays
      Can I use an old snowblower engine in my 90cc quad? The old one blew up.
      Thanks for the help.
