1987 honda trx 300 4x4 should I be worried??
i took my 1987 honda trx 300 4x4 out today threw some creeks and mud it did fine for about the first hour then it all of a sudden got real hot and started steaming i no the water would make it steam but it wasnt like a water steam or an oil smoke it was just like a light steam coming up threw the plastic around the handle bars just wanting to know if i should be worried. it still drove fine and had all of the power it was just steaming. i shut it off for about 5 min then it did fine the rest of the time.
thanx
Andrew
  • Admin changed the title to 1987 honda trx 300 4x4 should I be worried??
    • By Mhatayas
    • By BruceG
    • By hardcastle
    • By ResQ91
      Hi Guys!
      Or ??
      Dave
    • By Louznmemind
      Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues...  It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
