Chris2018
1996 Kawasaki Mojave KSF250 No Spark
If the bolt is broke and still in place what im trying to say is you can extract the broken part and simply put a new bolt in.  Thats what an ez out does.
Share this post
Link to post
  • Similar Topics
    • By ezduzit
      So my quad will start and run pull start, i installed new battery, solenoid, ignition. the problem is
      1 the starter will try but not start. the quad.
      2 when running i cannot shut it down with either the switch or the ignition i shut it down by allowing the fuel to run out.
      3 no lights come on headlights or brake lights
      when i turn the ignition on my neutral light works as well as the reverse indicator.
      any suggestions greatly appreciated.
    • By Daniel Gibson
      Have a 08 raptor brought to me a couple months ago. Got it on a trade for house remodel. Bike has around 30 hours. No that's not a typo thirty verifiable hours. The main Yamaha tech has put hands on this bike. Always Been reallyhard to start. If it does it runs really good. That's the kicker...IF! It started out intermittent now it's no spark at all. Everything ignition related is brand new. It all checks out good but still won't do it. Please help
    • By Joe Dickerson
      I decided to replace the rings and piston on this machine because it looked like the plug was being fouled by oil. When I removed the right side of engine to inspect the clutch pack, I found 2 small round pieces with tiny expansion rings in the bottom cover. It looks like "clutch pawls" according to the illustration, but Id like to be sure. I saw that there are 4 of these in the new gasket set.
      Can someone help me here?
      I thank you in advance
      Joe
    • By Dmitry Pesko
      Does anyone have an online manual for a 1991 Polaris Trailboss 250? Or, if they could tell me where the fuel shutoff valve is, that would be even better. Thanks!
  • Similar Tagged Content
    • By panthers06232
      it is a 99 mojave bought it couple weeks ago and it would run i relaced some stuff in the carb like the needle and seat and one of the jets put new plug in it and now it runs good until you rev it way up like wide open throttle then it misses almost like it is hitting a rev limiter could it be that it needs a new carb gasket or what are some ideas that could be wrong with this thing
