1993 Kodiak, bad reg/rectifier?
MarkinAR
I don't have a ton of electrical experience, but I think the basic workings of a regulator/rectifier are pretty straight forward.  3 diodes, so 2 power wires and 3 diode wires.  Symptom is relays click on/off, more or less no power, sometimes will work, mostly no electric to switch, can jump solenoid and it runs.
If i understand a reg/rect correctly, i should have constant resistance one way on each power wire.  So in a total of 12 ohm tests (3 per power wire, one way positive, one neg so 6 for one wire, 6 for the other), i should have 3 resistances one way on each power wire, am I correct? And they should all be reasonably close in resistance?
If i understand the way the reg/rect works correctly, then I have one bad diode as it doesn't read the same as the other 2 and this would be the cause of my issue?
All testing performed on the reg/rect unplugged on workbench, with a Fluke.
Thoughts?
That is correct you should get the same reading or close to the same.
Should have 5 wires, three  on one plug (phases) and two on the other plug   (positive and negative)
tester should have a ohm setting with the diode symbol. Take the red test lead put it on the black (negative) wire, take the second test lead and go from each of the three phases and the readings should be the same. Then do the same thing except switch the black test lead to the red (positive) wire and go to the phases again.  They all should be close. Any open/zero reading is a bad diode.
So it was a combination of things. Bad regulator was driving the electronics crazy and "on" side of the ignition switch was bad...no continuity. Replaced the regulator with a 2nd hand OEM and borrowed the ignition switch out of my big bear project and all is well.
I have a feeling the ignition switch was shot because the solenoid lead for the winch was just twisted in. So the solenoid stayed on all the time. Adding a rocker switch for that later tonight so the solenoid is only closed when I ask it to.
Purrs like a kitten. When we got it rings had been replaced so it's fairly fresh from a combustion standpoint. Wiring though is a dumpster fire. It's all together now, just have to wrap and secure some wires. Putting front wheel bearings in tonight and the oldest is headed to the woods with it in the morning. It's getting a trial by fire so to speak.
Got one side of wheel bearings done in 4 hours and left the other side for another day. What non ATV folks don't realize is that if you keep on riding dry and worn out wheel bearings it welds the outer race to the hub. Good times. 4 friggin hours for one hub. Die grinder, multiple chisels, blood sacrifice. But one side is done....so that's good.
    • By DarkRider
    • By ResQ91
      Hi guys
      battery and connections good
    • By huntindog
      TIA
    • By Jhb12686
      Hello I appreciate the welcome into the group. I am beyond frustrated with this desperate search for parts. I have a 2013 XY power sports UTV 300. I had a catastrophic failure in my rear differential which resulted in the destruction of almost everything inside. I have located everything I need to completely redo the rear end. But I cannot find a short side axle shaft with six splines etc. it's an offset differential and one shaft is longer than the other and I need the short one. The tip of it broke off (pic). Any help in getting another shaft for this thing would be GREATLY appreciated. Thanks guys
    • By mkibbe
      My 2014 750 king quad stalls sometimes when I touch or turn the handlebars,the problem has gotten worse,my machine has 475 miles and is only trail ridden,I have a new factory battery and i have 14.2 volts when the quad is running and 13.3 on the battery when not running,also using a multimeter there is no change in volts when turning the bars until it does stall,If I pull the 40 amp power steering fuse it will not stall.......I've been told its the ECU,Hate to buy one if thats not the problem,but its kinda leaning towards that,,,,,need some opinions.
