Daniel Gibson
90s Kawasaki bayou 220 have to cover intake to start
Start with the simple stuff: pull apart any connectors you find, check for corrosion, spray WD40 in them, remove plug cap & cut back the wire a bit for starters.
Share this post
Link to post
Def good to do as @spock58 mentioned. Reason I'm asking about damp conditions is my old fourtrax used to lose spark when it was damp. Turned out my cdi outer casing was separating from the epoxy fill and letting moisture in. If it dried out it had spark again.
Share this post
Link to post
Nothing is damp. The bike is inside my shop which used to be a guest house. It stays dry. I have jiggled all the wires while hoping on one foot while working upon a star and haven't had any luck. I cleaned the pig tails and every connector,check continuity, grounds are good. I put a little dielectric grease After drying everything with 90 percent alcohol.
Share this post
Link to post
  • Similar Topics
    • By Bryson Bailey
      Hey I have a Kawasaki buyou I put a new carburetor on it and a brand new spark plug coil and still firing up could you know what my problem is anyone please
    • By KDawgFPC
      I have a 2004  Kawasaki KLF300. I’m not sure What is the black/yellow, brown, and red wire wrapped together in the wire hornets of a klf300. I got it used and notice some wires not connected. They are located in the front area
      The reason why I am asking because I’m having issues with it firing up. I cleaned the carb put new spark plugs and gas.
    • By Shannon Battles
      I just got a used kawasaki bayou 250 and oil is leaking around exhaust stud are there any quick affordable fixes
    • By Michael Kastanis
      Hey I have a Kawasaki 300 boyu and it die in 5 gear and can’t get in Neutral try rocking it and moved it back and forth but nothing can same one here help me pls
    • By Michael Rogers
      Well this is my first time tearing down an ATV. Have done a little work on 2 stroke's in the past, but not much. I'm needing some help. I've got a Bayou that has lost compression. I tested it, and it was like at 40psi. I had already set the timing on it, and it does have spark fuel, etc...
      My question is about the cylinder. To me it looks pretty toasted, but need some help in determining. It is a 2000 Kawasaki Bayou 220. I bought it not running, just to see if I can get it running so it has not ran since I bought it. This question is about the cylinder, and part 2 I have will be about the CAM.
      Any advice / help is greatly appreciated.
      Inside sleeve a line(left line) runs the length that I can feel with my fingernail. The line on the right I can't feel.
      Some rust it looks like on these two pictures.
      Thanks!
  • Similar Tagged Content
    • By tnhomestead
      Just was given a 220 bayou, turns over and was wired by a crazy mouse on drugs helped by a committee of politicians taking advice from lil green folk from Mars! This is going to be fun. Claimed the stator was bad. My other project is an old lakota, died driving with no spark and has sat for a bit due to building a house n life! In other words,I may need lots of advice!
    • By Brother Buddy Gardner
      Hello everyone! I recently purchased this quad for a mere 300.00 and it is pretty clean for the year. I bought it from a guy who bought it in a storage unit. He didn’t know anything about it. I got it home and noticed it did not have an ignition coil for the spark plug. I bought the ignition coil, a new battery, new CDI box, new starter relay, new safety neutral relay, new carb and so on... I got it to turn over, but when I pull the plug and check for spark I have nothing.. it has a non factory starter button that works when I push it and turns the engine over no matter if the key or stop switch is on or off..not sure what that’s all about, but it does turn over..just no spark at the plug. Any help would be greatly appreciated! Thanks!
    • By Tom Pavlak
      Hi Everyone - Need some help.
      Got a nice little 220...clean machine. wiring is a mess. I have a diagram however, the one I have has 4 wires coming from the ignition switch not 2 like mine. So, I cant trace wires properly.
      There is a white one that runs to the Solenoid, and a brown wire...from the Ignition...I dont know where its supposed to go. Also, on the Solenoid, there are 3 wires..W to ignition, B to start relay and B/Y runs up to the front of the machine...and is not plugged into anything...and there isnt a "Mate" missing it. How do they plug into the 4 open shovels by the 20A fuse?
      I'm pretty sure my Lights and start switch/Lights are correct.
      Problem I cant get anything...new battery...cant get the start button to work, cant get any power to the lights or switches...so I know something is not grounded or..
      Any advice would be greatly appreciated.
      Tom
    • By Michael Rogers
      Ok, another newbie post here. Checking this stuff out in issues with lost compression. Wondering if anyone can tell by the pics and video of the cam is good, and whether you can see anything visibly with the valves and timing gear.
      Any input would be a great help. Been researching  youtube videos, but just not sure.
      2000 Bayou 220
      Valves
      I could test the exhaust, it looked like it was opening, closing and seating ok, but not sure about the intake.
      Gear
      CAM - looks like some wear on the outer ridges on both in spots, and one lobe to me looks kind of weird, but I don't know.
    • By Michael Rogers
      Thanks!
