Anyone getting stuff done at home?
By DarkRider
By joshua91673
first post
josh ohio
By Starsat
The choke lever doesn't stay in position on my 2001 Yamaha Kodiak. The model is YFM 400. I have to hold the lever to the choke position manually for some reason. Any Ideas as to why?
By Gwbarm
By huntindog
TIA
