Think its time to make a direct voltage adapter so I can check coil etc properly. Took an led, stuck in output from pickup coil and when turning engine over, the led pulsed in time. So kill switch and coil working. Hooked to output from cdi and led lit up and stayed lit. That doesn't sound right. But started raining so not sure if I had plugged the coil back in. Can't wait for a slab of concrete and a roof!
Share this post
Link to post
  • Similar Topics
    • By Steve Howard
      Ran find shut down the quad next day would start and idle when you try to accelerate it would start popping through the carb got a rebuild kit soaked it in chem clean after break down for 12 hours on slow vibrate reassembled and adjusted per manual still the same thing any help would be really appreciated thanks and happy ridding
    • By Denis Lanthier
      Hi All,
      I have a 2004 Yamaha Kodiak, which has taken me to many remote places and hauled lots of game.  I still love it after 16 years.
      Lately when I go to start it using the starter, sometimes it clicks and kills the power in the display.  Lights don't work, nothing works and I end up having to unplug the battery, wait awhile, and replugging the battery ends up giving the power back.   Using the winch will sometimes kill the power as well.
      Battery is new, all fuses are ok, I'm at a loss.  I can start it with the pull crank and it will work and so will the lights.
      Any insights or advice would be appreciated!
    • By gareth leifheit
      Ive got a Big Bear 350 4x4 that has been sitting for a couple years. It was put away running but now the pull start wont move and the starter wont turn it either. Any ideas what I can lube up or bang around to loosen it up? Thanks
    • By Maxx
      Hello Guys!
      Dumb question. How much oil registers on the oil level gauge while running? The oil level reads correct when off, but while running I can only see just a little bit in the oil level gauge. Makes wonder if the oil isn't circulating well enough.
      Also, whats your preference in battery brands for ATV's (standard or AGM). We don't ride it all that often.
      Thanks in advance for any info.
      Disconnected the plow yesterday on my 2004 Yamaha Grizzly 660 and am getting ready to do some riding yesterday and the battery went weak, Starter cranked a few times but week. Put my trickle charger on that I bought and went to the garage today to start it up, but the starter is just spinning and not engaging. The solenoid is clicking. The pull start sucks and is hard to pull (never use it and need to look into that). Quick video of the starter spinning. Could it be the starter or  the starter clutch one-way bearing? I guess I need to take the cover off to see what's going on.
      2004 Yamaha Grizzly 660 Starter Spinning.mp4
  • Similar Tagged Content
    • By Maxx
      Hello Guys!
    • By Maxx
      Hey Guys!
      Can anyone out there possibly provide the torque specs and sequence for the gear case/ clutch cover. Need to replace a leaky gasket. Thanks in advance for info.
    • By 87tecate4
      View File Lakota KEF-300 Service Manual 1995-2004
      Kawasaki Lakota 1994-2004 Service Manual
      Submitter 87tecate4 Submitted 07/10/2018 Category Kawasaki ATV
    • By 87tecate4
    • By M C
      Hello all!
      A friend of mine has this particular 4 wheeler. It sat in the garage for about a year, so I redid the carb, cleaned the tank and installed a new petcock. So far, it cranks right away whether its button started or pull started. So I have a couple of questions concerning the carb and air filter.
      1. Is this a cvk32 250 or 350 carb? As the air fuel ratio adjustment is different according to a cvk document I read. What's your adjustment setting? 2 whole turns and a 1/8 or 2 whole turns and a 1/2? Comparing the old setting on the carb to the new setting (and where the needle sits now), makes me think it was way off before.
      2. The Air filter cover, gasket, air filter and plate element are all missing. So I was thinking of removing the hose that goes to the air box and put one of those K&N style looking filters and be done with it. So my question is.. will I have to readjust Air Fuel screw or just adjust Idle?
      It's just going to be driven around the neighborhood.
      Thanks in advance for any info or help. Y'all stay safe out there!
