Birthday?
By joshua91673
first post
josh ohio
By STLJ
Hope everyone is having a great weekend,
While riding my quad just quit, I mean dead. No life on the dash, no crank and obesity no start.
Had a quick look under the plastic, batt reading 12.7v power at the key switch.
Changed the power pack, still no luck.
Anyone else have similar problems?
I don't see a fuse box/panel, is there fusible links in the system? If so where di I start looking?
SK
By kawasig
By beast6228
It's been a long time since I have used a forum, I was the admin of one for quite a few years, had thousands of daily active members, with lots of crazy posts and spammers, so I salute the admins. Anyway, just waving my greasy hands, Hopefully I can help others out.
By n4cer26
Just bought a non-running 425 Magnum 6x6. Guy said previous owner had motor rebuilt (3 years ago or so.) It reportedly ran great but recently the electric start began failing and he put a new recoil on it which he broke immediately.
I get it home and put a new recoil on it and the pull is incredibly hard....so much so that I think I'm going to break the new recoil assembly. I also installed a new starter which won't roll it over either.
I'm thinking maybe a hydro-locked situation so I pull the plug and the motor rolls over fine with both pull start and electric start. The cylinder was dry however.
Checked the valve lash and it was right on at .0006".
Checked the compression relief spring on the end of the cam and the spring was strong and keeps the metal piece against the dowel like it should. The cam lobes look good from what I can see.
I have a small camera that I dropped into the cylinder. Could t get a pic of the entire chamber because of the angled engine but there are marks on the center piston and a couple of grooves once side of the piston top. I will include the photo.
Anyway....I'm at a total loss at this point. Not sure how to proceed and diagnose. Would sure appreciate anyone's help who might know what the heck is going on! I was able to get it to turn over about 5 times with electric start with compression tester installed which read 145 lbs. I don't know what else to do!
Reply
Sent from my SM-F926U using Tapatalk
