Artic cat 500 in a box…well several boxes
Similar Topics
By BioWare
For all of you guest out there. You should become a member today. There is no better time to join then right before the spring.
Get all of your riding tips and gear info here at Quad Crazy.
Meet new/old riding friends.
Just seeing if we can get some new members, you do not have to join. Just wondering if you would.
By chadd7
I bought a used 2019 ds 70 a couple weeks ago for my son. If I had to guess it has under a 100 miles. It still has the nubs on the tires.
It starts right up on the first crank. After he rides for a couple minutes it will stall when he stops. If he doesn't stop it won't stall but as soon as he stops it shuts off. I can get it started but it take about 3 minutes of cranking the engine before it will fire back up. Then again after a couple minutes of riding it will stall as soon as he stops. Any recommendations?
By trx125flip
yay forum stuff again... really needing a 87 trx125 service manual.. if anyone has one without a dead link that would be super!
By Ajmboy
For years I've been wanting to get my rowboat back out on the reservoir here in lower NY, just never found the time and every year came and went. Its NYS watershed and NYC water supply so you have to have it registered, tagged, and cleaned before getting a spot on one of these. Now I just need to dedicate some time to get out there and fish! You end up leaving it chained to a tree and it stays out there for 3 years before renewing it again.
By TSWIII
I let my ArticCat sit over the winter but before it was put in the garage it was running perfect. In taking it out this year it wouldn't start. I can start it with a charger and it will idle just fine. But it's doing something weird now. Either the display 1)won't display anything or 2) it will just display the analog speedometer but none of the digital stuff or 3) it will display all. So it was acting really sluggish when in HIGH gear and sounded like it was in low gear. So in driving it down the road and it being sluggish, I switched the ignition key to "Lights ON" and the ATV immediately picked up as though it really was in HIGH gear. Switching the ignition back to "ON" was like down shifting into LOW gear. When I came to a stop and switched from LIGHTS on to just ON the ATV completely died. After a 30 minute ride you would think it would start again but I had to jump it again to get it to start. Same issues with the ignition having to be pointed to Lights for it to run decently. Then just as I got back to home base the display showed VOLT. It acts like it's something in the ignition but not sure how that's related to the gears. I put a gas cleaner in the tank since it's been sitting but it really doesn't seem like a bad gas issue that I thought it was at first. I checked the IGN fuse but it seems fine, replaced it with the extra fuse but no joy. Anyone have any ideas?? Thanks in advanced for any help. It's much appreciated.
Similar Tagged Content
- 4 replies
- 789 views
- 2 replies
- 1,735 views
- 6 replies
- 4,038 views
- 7 replies
- 10,981 views
Gallery Images
5By monkey420,
7By NY_Vmax_Joe,
0
3
2By BCFusionGK77U16,
3By slrileyk,
1By Fox_Rider_17,
2By FIFTY_ONE_50,
5
3By psutsra2,
6
4By Deeds,
0By Guest,
1
3
0By Chomp,
6By wylde1,
0By Crusty72,
2
0
