Fuel shutoff
Similar Topics
By Atvguy0901
Thank for the add on quad crazy. I am new here and need some help with my atv. It’s a older Yamaha Timberwolf 250 that I purchased second hand from an person. I got it home ans started to look into it. He stated it needed a cdi box so I ordered one for it and a battery as well also a key switch cause it did not come with one. I put all the parts on it and when I hit the start button it just clicks and noting else. Thank you any help is appreciated.
By Yourmanyoshi
I have a kawasaki klf 300b 1987 and when i got it originally from a friend it was sitting for like 10 years and of course it didn't run so i went through the steps of fixing it. Had good compression and clean carb but i wasnt getting any spark. I went through the steps of fixing that and turns out the cdi box was bad, so i replaced that and got spark so i started her up and she was a little scared at first but slowly broke in and idled perfectly fine. But everytime i gave it any gas it would just bog out completely so i had it idling and sprayed starter fluid into the intake to see if it would rev up, but it did the opposite and died out. I think it might be something to do with the spark since after that i took it out and it was wet. Im guessing its not sparking at higher rpms but i have no idea how to fix that since ive never had that issue before, keep in mind ive cleaned the carb maybe 5 different times with a supersonic cleaner and put needles through all the wholes. Someone please help me out with this old *** atv
By Ajmboy
This service manual is for a 1986-2006 Kawasaki Bayou 300.
Adding to downloads library.
By Georgia
I bought this quad new. When my quad gets warm, It starts skipping at around 2,000 rpm and won’t idle.
By steve shugart
Hi all, does anyone have an idea what the time involvment is to R&R a fuel tank on a FTX-4WD KQ 300? and possible ballpark $ ?
Gallery Images
