Stoopidbot1
2010 Yamaha Rhino Sneak Peak
Don't worry about where I got them, but here is a few pics of the supposed 2010 Rhino.
Did you notice the 2nd row of seats?:no::confused::rolleyes:
Share this post
Link to post
Oh yeah, look at that...more seats. Did it always have power steering? I know the grizzly has had it now I believe 2 years.
Share this post
Link to post
  • Similar Topics
    • By AKATV
      For those that have been pulling hair out-
      It took me a month to figure this out, but I am glad to report that I have figured out how to repair my 2004 450ES Speedometer
      If you have a Honda Foreman 02-04 450 ES model ( 4 indicator lights on top of meter)
      or a Honda Foreman 99-00 450 ES model ( 3 indicator lights on top of meter)
      or aOnda Rancher 00-03 TRX350ES
      and your display:
      - Is Blank
      - does not show the gear indicator spot at all (not the gear or --) but the
      backwards "L" that goes around the gear position - its just blank
      -your miles and hours have reverted to zeros or all 9"s and possibly now shows KM now instead of Miles
      -your speed shown seems to have almost doubled (possibly KMs per hour even thought it shows Miles)
      What has happened is your EEPROM chip on motherboard has lost the programming due to dead battery for
      a LONG time or an electrical malfunction etc...
      I have borrowed a friends speedometer (a trusting friend) removed the chip from his, copied the data and put it on mine and it reads perfect now.
      I can repair your speedometer it will have 1851 miles and 317.2 hours on it as that is the only copy I have for the 02-04 Foreman 450ES
      I can also do 99-2000 450ES speedometers (3 indicator lights on top of meter) but will have to double-check check on the mileage/hours copy I have and let you know to see if you want that
      I can also do TRX500FM and FE meters and the older Rancher 350ES meters as well but it has to have the above symptoms and not water damaged-caught on fire, cracked lcd, etc....
      If you have one you want repaired just send to me (just the board with LCD) I can repair it for you for $45.00 or barter if you have a second bad meter for parts
      Shipping would be 4 - $5.00 for First Class with tracking and I will pay return shipping
      I will confirm and send pictures to you as well to show a working completed repair on your display
      If there is heavy water corrosion, rust and rot damage etc.. its probably not repairable but I can try if you want -no fix-no pay
      If you PM me or whatever we can work it out I am easy and like you all I am always fiddling/learning with wheelers
      I think you will be happy and you will have more hair -mine is filling back in...................
      Message me if interested
      I am now also doing burned out screen repair if your screen has become unreadable due to UV sunburn damage from the sun
      It will appear burned or melted.
      The cost is 45.00 with same or next day turnaround
      Will do partial barter if you have a second speedometer for parts
      PM me if interested
      Before and after pictures below
    • By PKR
      Neighbor dropped off his 2010 Ranger 400 HO. Said it was missing and backfiring. I replaced the plug as it was carboned up (kids use the side x side for chores and it is only idled around yard) Unit ran great, sent back home and it ran great for about 5 hours of run time and then it wouldn't start. He brought it back and I changed the plug again and it would start but would not run great. Pull plug and it was really wet. I suspect the carb needs cleaning and that is the direction I plan on going unless someone else knows anything about these units. ( I have never worked on one of these).
      If you know of something else I should check let me know.
      Also I am looking for a service manual for this unit.
      PKR
    • By Rick Shropshire
      Happy New Year all! Remember not to operate any vehicles while under the influence, you could get busted or worse, you could get hurt or hurt someone else who's playing it safe and end up in jail. Have fun and be safe.
    • By Ellery Zandt
      I have no idea where the antifreeze line coming off the thermostat goes too. The carb two nipples in the pic create a vacumme. Can someone help me on this please....!!! my email direct is [email protected]!!!!
  • Similar Tagged Content
