    • By p5200
      Do most of you reset this initial adjustment according to starting spec when you replace the factory OEM carb? Mine says 2 1/4 turn out so that's how I set it for now.
    • By Brad Leeson
      Can someone please tell me where the pilot air jet is located? I can't find anything other than on the pilot jet. It's on a 2005 yfz 450.
    • By oxidized_black
      1989 Honda Pilot FL400R service manual
      View File 5851d7bd8b7c0_1989HondaPilotFL400RServiceManual.pdf
      Submitter oxidized_black Submitted 12/15/2016 Category Honda ATV
    • By CACRWLR
      Hi,
      This might be a dumb question, but can you adjust the carburetor pilot screw on a '99 King Quad while the carb is on the atv?  There doesn't look like there's much clearance between the pilot screw and the cylinder head to get a screwdriver in there (if I'm looking at the right screw).  The engine runs pretty good; there's just a slight hesitation in the lower rpm ranges.
      Thanks.
      ride 2017 Can-Am X Team Contingency
      The program includes more than a $350,000 in total payouts. View the full article
