By
Guest Fox300exchic
in Where To Ride Your ATV
By p5200
Do most of you reset this initial adjustment according to starting spec when you replace the factory OEM carb? Mine says 2 1/4 turn out so that's how I set it for now.
By oxidized_black
1989 Honda Pilot FL400R service manual
View File 5851d7bd8b7c0_1989HondaPilotFL400RServiceManual.pdf
Submitter oxidized_black Submitted 12/15/2016 Category Honda ATV
By CACRWLR
Hi,
This might be a dumb question, but can you adjust the carburetor pilot screw on a '99 King Quad while the carb is on the atv? There doesn't look like there's much clearance between the pilot screw and the cylinder head to get a screwdriver in there (if I'm looking at the right screw). The engine runs pretty good; there's just a slight hesitation in the lower rpm ranges.
Thanks.
By ATVNetwork
ride 2017 Can-Am X Team Contingency
The program includes more than a $350,000 in total payouts. View the full article
