By Its-always-something
By Clydaho
Any other ideas?
Thanks for any help,
Clyde
By Topendcol
Col
By joshua91673
first post
josh ohio
By Andyjack
Hi everyone new to this forum, i just got a LT80 for kids to learn on but can’t get it started. There is a spark but not very good so changed coil but got one with separate cdi so wouldn’t work cleaned car but still no joy. Fuel is getting in as plug is always wet. Im baffled. Like i say there is a spark i was thinking timing might of slipped so going to try that. any help please really appreciate it.
Similar Tagged Forum Content
- 4 comments
- 5,047 views
- 4 comments
- 3,130 views
- 4 comments
- 3,172 views
- 15 replies
- 3,635 views
- 5 replies
- 7,364 views
