Guess Who Game!
      I have a 97 Yamaha Timberwolf and it is beyond loud, is there any good options to silence them or at least make them bare able to drive. I know it has a crack in the exhaust pipe, but even with that fixed its still loud.
    • By joshua91673
      hi every one .anyone out there my issue is my kick start wont stay out  i have to have some one pull it out.  it pull out easy just wont stay out to kick it over .kicks over and starts no problem
      first post
      josh ohio
    • By That229Yamaha
      Hey guys, I’m new to the forum. What I got is a 2001 Yamaha Bear Tracker 250, got it as a project on trade and the problem I’m dealing with is a “no spark” problem and been trying to hunt down the cause for two weeks. I’ve replaced the stator, pick up coil, CDI, wiring harness, ignition, coil pack, spark plug, solenoid, battery, etc. and I’m still not getting any luck. Even tried bypassing the kill switch. I also noticed two things on this quad, another CDI under the back plastic by the voltage regulator, and a blue and green wire coming from the motor behind  the foot shift, tried to hook it up but it broke off and I’m thinking the broken wire would cause it to have no spark, if not then I need someone’s help on this and wanna see if I can get spark again. If anyone knows why I have this problem, the help would be greatly appreciated.
    • By Dezertrider65
      I just have a question.
      If I was to buy 3 Wheeler from a private party say a 1985 Honda 350 can I get it made street legal and if not can I still ride it out in the Arizona deserts?
    • By Wonderwoman
      I am hoping that someone here can give me some more ideas. Our poor old red 300 won't start. We rode it, running fine, shut it off and now it won't start. Have gas to the carb and spark at the plug. Valves are adjusted. Still won't start. Tried a little starting fluid in the air chamber and still won't start. This poor old machine has 7000 miles on it. That has to be an Arctic Cat record! And I have never touched the engine besides setting the valves. Unfortunatly it looks like it only has 60 psi of compression. Don't understand how it could be running fine and then nothing. Someone give me a clue as to what I am missing or what to check. I was going to rebuild the top end this next spring but didn't want to do that this winter in a non-heated garage. Any help?
