By gatorschevy
04 Suzuki Quad runner 400
86 Kawasaki bayou 185
96 Polaris magnum 425
95 Polaris trail blazer 250
03 bombardier 175 rally
92 Yamaha moto 4 350
By kiriyaaoi
By Suzukiquad
By ATVNetwork
By p5200
The studs in the sprocket hub are stripped out. The hub is probably walloed out also. Probably will have to have a new sprocket hub. I doubt I have the ability nor the tools needed for this job. Thanks for all suggestions/opinions!
20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4
Similar Tagged Forum Content
- 0 replies
- 2,853 views
- 1 reply
- 2,256 views
- 0 replies
- 1,938 views
- 0 replies
- 1,716 views
- 0 replies
- 1,713 views
