April 2011 ATV Photo Contest!
Theme: "Best Trail Riding" with your ATV, 3 wheeler, or UTV.
Prize: RZR Mask (Black) Sponored By: RZRMask1
Visit the RZR Mask thread here on QUADCRAZY...click here!
Rules: Submit your "Best Trail Riding" with your ATV, 3 wheeler, or UTV by entering it with a post, into this thread. (If you are not familiar with how to do this, visit the Learning Center) One photo per member allowed, so make sure it's a winner. You may submit photos that have not won past contests. Photos can be of yourself or taken by you. You may not submit photos that you do not have ownership of or permission to use. Any violation of these terms will result in disqualification.
Last day to enter a photo is April 26th.
Voting will take place for the last 4 days of April to determine the winner.
Voting will end April 30th and the winner will be announced...Good Luck!
No, it's the power lines in lower NY. Is wellsville in NY? By the way, nice pic, but for the contest entry it needs to be a pic with your ATV, 3 wheeler, or UTV.
Got a pic with your quad on those trails?
AW darn, oh well I will have to try and find one unfortunately my hard drive crashed a while ago so I lost a lot of pics and vids but I'll look. And Wellsville is like the biggest place to ride in Ohio with ridiculous trails and hill climbs. It is right on the border of Ohio and PA.
2 more days left. ATV, 3 wheeler, or UTV.
well what about a snowmobile if i want to use it as my pic ? its an atv just for the winter months ....
Unfortunately no. ATV, 3 wheeler, or UTV.
    • By mehim
      Hi everyone.
      CARFAX https://www.carfax.com
    • By Bobbywolf
      I am working on a basket case for a friend.  It is a 98 Big Bear (YFM350FWB).  It came with a parts machine which is a 96, which I am coming to find out is VERY different from his machine.
      Anyway, first thing is first.  I checked compression, 150psi.  Valves are set correctly, and the engine is in time.  I cleaned the carb, and there was some junk in the passages.  It is a chinese carb, which I figured from the lack of markings or lettering altogether.
      The bike runs.  It idles ok, but breaks up badly under acceleration.  Pulling a new spark plug shows it is running lean.  White strap, with no black whatsoever.  So I have the carb adjusted with the mixture screw out way too much (about 5 turns), and the diaphragm needle lifted to the top slot.  It is still not getting enough fuel (or too much air).  It backfires through the carb, and cannot get above idle without carrying on.  The carb boot is in good shape, so it isn't pulling any air there.  I did test this as well by spraying ether around the boot when running, looking for intake leaks.
      Anything big I am missing here?  I am starting to believe that this chinese carb is the issue.  This quad came with the original carb, which I would like to rebuild and use, but the mixture screw is totally stuck, and stripped way down in its recess.
      Thanks for any assistance.
    • By jashadams
      Snapchat-1142015191.mp4
