By kiriyaaoi
By huntindog
TIA
By vlxerdon
Hello from southeast Georgia. Was gifted a 2000 Yamaha bear tracker with out a carb or battery and looking like it had seen better days. Was told it had sat for about three years. Explained a lot. Put a carb on and a battery in and it started right up. Surprised the heck out of me Anyhow as stated in my opening I am 78 years old with a very long motorcycle backgground but brand new to atv's. Anyone else out here from Georgia? Would like to meet up with some folks for a ride or two. Looks like a great site. Thanks for having me.
Don
By Frank Angerano
Similar Tagged Forum Content
- 6 replies
- 1,503 views
- 0 replies
- 1,917 views
- 4 replies
- 1,985 views
- 1 reply
- 1,531 views
- 3 replies
- 2,700 views
