1994 Polaris 300 2 stroke chain issues
Ghost420guy
My friend recently rebuilt this 300 2 stroke, .06 over bore, full aftermarket exaust, clutch kit and jetting. He's snappin chains ike its goin outta style, several of us have checked chain tension but they keep snapping. First ever i seen in 2 pieces lol Does anyone have an idea on why this keep happening? Just about every other ride it snaps, and he runs 520 o-ring chain
Check the alignment of the sprockets. Dont eyeball them either use a laser. If they are aligned then adjust to proper slack. Drive easy then get on it a little. Ride this way for 20-30. Check chain slack and adjust. Then eyeball the slack every time you ride til it stops stretching then maybe every 20 hours check it. Or weekly whatever.
Tell your buddy to stop being a primadonna and take care of his machine properly
Does his model have a non-concentric swingarm? If he has this, the tension constantly changes as the swingarm moves up and down, thus overtightening during riding. It's either too tight, or as Mario said, the sprockets are misaligned. The next chain he snaps may end up in the back of his head or through the engine block, not to mention damaging the tranny. he needs to "cool it" during the break in period too or his new sprockets will be toast in no time. You did'nt specify which model he has, only the year and cc's. Hope this helps!:wink:
if my memory serves me correctly then yes that p0laris 300 should be a swing arm set up. i agree with cheriah back off the throttle and check for proper alignment. also. you should have approx 1/2 to 3/4 of an inch chain slack with a swing arm to allow for the travel.
What am I chop liver?? J/K
Lmfao! I love where this thread went lol I'm goin out to his place this weekend and I'll check the alignment of the sprockets, it is a swing arm set up and hes put alot of money into this machine. Just about everything on it is new, we jus ride really hard. I'll pass the info on about breakin in the chain n if he doesn't listen well pi@s on him, I tried to help lol He's upgrading in a year anyways, tired of bein the slowest n weakest machine hehe U guys crack me up lol
Sorry i cant find the hijack smiley on my phone.. Its there somewhere o_O
    • By hardcastle
    • By skittle021
      Photos:
    • By Louznmemind
      Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues...  It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
    • By Its-always-something
