91 Suzuki Kingquad 300 low compression, wont start
bsfs1988
Hey guys hope everyone is well. I need sum advice or help. Anyways I already rebuilt the carb however I noticed that the carb is spitting sum gas towards the airbox and i did a compression test and i only got 50lbs what should the compression be for these lil monsters bc 50 lbs isn't a lot I figure it will b around 100lb or so. So I'm thinkn a piston,bad valves? it does smoke white but I can get it to run but hard to start and I got to keep the slide all the way open on the carb to get it to even run but once I let the slide down it cuts off so its not even driveable right now plz help me guys trying to get it running b4 we get snow
Thanks guys unfortunately I dnt have a book so I dnt know how to check timing and valves I'm pretty much doin this with out a book and mainly guess wrk. It does have around 5k miles on her and the recent owner didn't maintain it very well. Any tips on how to check that stuff. If I have to break it down anyone know where I can get a good performance cam for it and get it bored to next size hopefully that will give me sum extra power
So I set my valves again and it cranked up first time it ran about 2 mins then cut off I got valves set int .004 exhaust .005 I put it on tdc by taking plug out and feeling for air then use the hand starter to put piston on top I got needle jet about 2.5 turns out should I turn it in some so I can get it to idle. And got new spark plug gapped at .26 any tips guys or ideas what I should do or check
What's up ox. Naw I dnt know y it shut off. When I reset the valves she cranked as soon as I turned it over. I do have my air mix screw turned all the way in til I can get it to idle and get it set however when it did crank it didn't idle high with the air mixture all the way in which it shud have. I'm thinking its fuel problem bc when I took old plug out it was extremely black and had residue on it as well so burning rich right?. I got the needle jet set at 2.5 turns out frm seated. It's almost bck to same problem it will crank if I raise the slider half way up to give it more air
I got it to idle and kinda wnts to bog when I give it gas then after playing with it a while I can give it gas however when I give it full throttle for about a min she will cut off and I noticed the float bowl is completely dry! Any ideas ? Bad float or bad float spacing or sumthn
Could be bad fuel lines or fuel filter/pump. Pilot screw setting might be closed too. And your going to want the valves a 6 thousandths and maybe even 7 thousandths for the exhaust valve because it will expand a little with the heat.
And make sure you run premium fuel in there because anything else is terrible on the carbs
Edited by Thayer40
    • By BruceG
    • By ResQ91
      Hi Guys!
      Or ??
      Dave
    • By Clydaho
      Any other ideas?
      Thanks for any help,
      Clyde
      I just bought two 2002 Suzuki LT80K. Do I need to mix the gas or use straight unleaded?
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
