By CaptJim
Hello guys, I hope I am not invading your space, but as you can see the current state of my project here it's not but about 50% ATV. I am hoping that some one here can point me to a wiring schematic that I can reference since the "Complete wiring harness" i purchased from Amazon did not include a diagram of any kind.
The ones that I am finding on line vary greatly but none show the connections for the separate 5 wire connector coming from the motor.
Can someone tell me where these wires go?
Thanks in advance for all help!
By Suzukiquad
By luckyyyyesther
Hey all!
By Bobbywolf
Thanks for any assistance.
By p5200
Similar Tagged Forum Content
- 1 comment
- 3,187 views
- 2 replies
- 2,655 views
- 0 replies
- 5,148 views
- 0 replies
- 5,075 views
- 0 replies
- 1,782 views
