By Gwbarm
By 97kingquad
By dlw
i have a 2016 kymco uxv 700i and i am having issues with transmission. it makes a horrible noise in 2 wheel and wont move. it will move in 4 wheel but still makes noise. has anyone had this same issue?
By 86096
I have recently acquired a 1985 Suzuki lt230ge quadrunner. It has an automatic clutch. How do you ride it. do I select a gear and then give it gas and it will go? What about downshifting? I don't want to jump on it and go and risk busting something on this old rig. Any advice would be appreciated. Thanks in advance!!!
By ericggg
Hi, all
I have a 2010 Honda try 420 at and I'm having an issue with the transmission. Every now and then the while riding the transmission goes into neutral or stays in gear high or low. Recently while riding it stayed in 4th gear, had to come to a stop and rock it back and forth and it want back to first. Did any one have similar issues and what can be the diagnosis to this problem and is it worth fixing. I called the Honda atv dealer and told them what happened and they said it's going to be $2000-$3000 to fix that seems crazy. Any help or idea will be greatly appreciated.
Thank you all
