bodatiouskid
Cant get into park
Have a 2007 Yamaha Grizzly 660 4x4 ATV.The problem is I cant get shifter to go in park.Had lost the mounting bolts to the shifter but still could get in park.Replaced bolts & now cant.
Any suggestions?
Share this post
Link to post
When stepping on the foot brake pedal, there is a pin inside the shifter assy. that pulls back to allow the shifter to be moved into reverse and park. Because you were still using it without the bolts holding it in place, you may have damaged the cable going to the shifter or caused it to go out of adjustment. Adjustment is directly in front of the foot brake pedal. Otherwise you have probably bent the linkage. I have found that linkage to be a pain in the tail to adjust. Good luck.
Share this post
Link to post
  • Similar Topics
    • By Asen_77
      Hi All,
      My name is Asen and I am from Eastern Europe, Bulgaria. Riding a Yamaha Raptor 700R and this is my first Quad wanted for a vey long time :)
    • By Julio Cano
      The tires which I bought on ebay cannot be balanced, it’s out of round.Tried riding and had wobble.
      It was mounted in shop and they also put it on a rim they had sitting in the shop and same issue to confirm it.
      Are they defective ?
      They have brand new high quality tires for my  old suzuki gsxr750 and want about $600 for two tires.
      Is it worth it to pay that much or buy another set of front rear tires like Hexautoparts which has good reviews on trustpilot.com?
      Any recommendations ?
      Thank you.
    • By dgk_mike
      It will go into neutral, 1st, 2nd, and reverse but nothing after 2nd gear. The shifter moves freely going up completely nothing but when you shift down it works. I’m not sure if it’s tranny issue worth messing with or if I should just buy a new one.  Overall besides that the thing runs like new.
    • By MarkinAR
      I'm likely going to have to drop the swingarm on a 300FW. Are the lock rings and pivot bolts standard or left handed threads?  I looked at the service manual and it doesn't specify left hand so I"m assuming standard right handed threads.  Not sure though.  The last Yamaha I had apart was regular right handed threads but haven't had a 300 apart before.
    • By StolenATV
      Taken from my car port around 0330 and was taken by at least 2 people found footprints pushing the quad all the way to the road (80 yards)
      The post 2012 Yamaha Grizzly 700 EFI 4×4 Stolen appeared first on STOLEN 911.
      View the full article
  • Similar Tagged Content
    • By drifterss454
      im hoping that somebody could help me out changing my shifter on my 2014 outlander 400 max xt.,I kinda need step by step instructions,a brain aneurysm a few years ago has left me kinda useless sfiguring things out anymore,i think that hey took away the part of my brain that actually worked,lol,i did get the seat and plastics off,cover off the box,thats it,geez,i put more hurst shifters in my cars,cams,domes,cranksetc and now I cant figure out how to put a new shifter in my bike,more snow coming tonight,so, I"ll need my plow,,so I hope that somebody can guide me in changing the shifter,thanks all
    • By vedder37
      Title says it all. When I researched part it shows it does not exist anymore, discontinued. What can I do to stop the leak? Is there somewhere else I should be looking for part? The leak is coming from where shifter goes through seal, not around outside of seal between case and seal.
      Thanks.
    • By jprusha
      I have a 98 Timberwolf 250 5 spd. I would like to find a heel toe shifter and have been unable to find anything.
      Does anyone have any idea?
      Thanks-John
