shchuck
2005 Kawasaki Bayou 250 - Carb Probs
It starts fine well ok then when it gets warmed up good it rill run so fast that the brakes just will stop it. I need help please
Thanks Shchuck
Share this post
Link to post
the carb may be a little dirty, you can spray some carb cleaner in while its running and that may clear it. im not sure if there are vacuum lines on it, check those if it has. there may also be an idle screw you can adjust too. for now, i would try the carb cleaner and there is a product called "seafoam", that is an additive for your tank. run a tank of fuel with that in it too ...
someone else with a kawi bayou may jump in and give some more tips for you ...
Share this post
Link to post
in the manual it also mentions turning the handle bars left and right to notice if the rpms change, if so, the throttle cable is bound up somewhere or pinched ...
Share this post
Link to post
  • Similar Topics
    • By oliverstevenrjr
      I have a 425 Magnum that idles great but seems to flood out when I rev it up, sputters, backfires a little somtimes. No water in gas, good fuel filter, carb seems to be fine, good working diaphram. Plug change makes no difference whatsoever.
    • By technofarmer
      Hi there i was needing to ask a question. I may soon be getting a UTV of one sort or another and not sure what is good or better to avoid?  So far i hear great things about the Arctic Cat Prowler and Havoc, and many speak well of the Kawasaki Mule all but the 610?
       So what are your thoughts and especially experiences?  What have you had and used in farm life and trail riding that has held up well or hasn't?
    • By Chris Stokes
      What is a good option for a 13 year old that is dying to get her very own atv to ride? Thanks in advance for your recommendations. I currently own a Polaris Sportsman 570 and have been happy with the Polaris sportsman line but have ruled out other brands.
    • By Cj Winds
      I have a 2000 Polaris Xplorer with the 250 two stroke motor
      It does not want to start with the electric start, the motor cranks fast, the battery is good, and there is good spark when cranking. The engine starts perfect when using the pull cord, it even starts if I pull the cord slowly and starts with one pull. The engine idles smoothly once started. My wife says she needs the electric start to work.
  • Similar Tagged Content
    • By Michael Aiken
      Where can I find a wiring diagram for my 2005 450 Kodiak. Thanks.
    • By Mo Salem
      So my front hub broke, I’d like to put aftermarket on. Hard to find new oe ones. Please help. I’m new to all of this, I have some car knowledge and try to apply it
    • By oxidized_black
      tag : zukifreak
    • By LMI
      Was using the quad the other day to shuttle wood from my pickup to my wood pile.  When the job was done I turned off the Quad and heard a bit of a racket from the front end.  When I got down underneath the sound seemed to be coming from the fan housing.  fan was moving in spurts and not quickly... much like a computer case fan that's had it's day.  What I know.
      Temp sensor is ok, as the fan tries to activate fan is getting some voltage as it is attempting to spin.  When I first bought it used I tested the fan direct to battery and it was fine. The fan was working ok even not direct wired as I went on a couple of rides and when stopped and idling the fan did run Seems to be free spinning with my finger read up in the manual and they require me to drop the rad.  now I'm not opposed to that as the rad has some damaged areas I want to try and straighten out.  But if I can get the fan working without, I can leave the rad as it is until next year.
      Fan assembly is about 300 bills, any work arounds or alternatives?  I even thought large computer case brushless fan.  smaller ones are about $7 larger ones better quality probably far below the 300.  They run standard 12v DC.
      Anything I should be doing before dropping the rad... other than check for obstructions even though it seems to spin, and trying to hardwire it to the battery again for a test to see if it acts the same?
    • Guest Fox300exchic
      By Guest Fox300exchic
      The Hop-Up: You may be saying to yourself, “that’s a chick bike,” and you’re right. But honestly, it’s so much more than that. It’s one badass bike. http://www.quadmagazine.com/quad/features/article/0,24942,1587044,00.html
