What 2 stroke oil are you using?
You can use Valvoline:
2-Stroke Motor Oil
Valvoline Motorcycle Oils contain proprietary blends of premium base oils and advanced additive technology to help you achieve peak performance from your machine.
Available at: Auto Zone; Checker, Schuck's and Kragen; Murray's; and Blains
Valvoline 2-Stroke Motorcycle Oil is formulated to help:
Protect at High RPMs and Temperatures - Excellent film strength and lubricity to help protect engines at peak RPMs and temperatures, minimize piston scuffing and protect fuel injectors.
Achieve Maximum Horsepower - Clean-burning to maximize acceleration and performance.
Protect Vital System Parts - Special dispersants to help prevent piston ring sticking over the broad range of engine temperatures.
Reduce Exhaust Smoke - Advanced additives burn clean and significantly reduce visible exhaust and exhaust port blocking.
Achieve Proper Fuel Mix - Special balance of advanced components to allow thorough mixing with fuel.
Part Number VV746
Size 16 oz
UPC 0-74130-00746-8
  • 3 months later...
2-Stroke Motor Oil
Part Number VV746
Size 16 oz
UPC 0-74130-00746-8
I use thsi stuff and I buy it at CARQUEST.
  • 3 months later...
    • By BruceG
    • By Mhatayas
    • By ResQ91
      Hi Guys!
      Or ??
      Dave
    • By Charlesbrown
    • By Lafytafy
      should i run a thicker oil in a older quad because it make a little more noise than usual
