400ex kicker
:wacko: This obivously isnt going to go anywhere with you. Im waisting my time. So ive edited my post so it doesnt keep going. End of discussion. :skeptic:
I had not planned on carrying this topic any farther. You did not waste your time every opinion should have a value wether anyone agrees or not. As long as people keep buying atvs and riding them that is all that counts.
I will not post on this topic again.
  • 8 months later...
  • 3 years later...
  • 2 years later...
      I have a 97 Yamaha Timberwolf and it is beyond loud, is there any good options to silence them or at least make them bare able to drive. I know it has a crack in the exhaust pipe, but even with that fixed its still loud.
    • By joshua91673
      hi every one .anyone out there my issue is my kick start wont stay out  i have to have some one pull it out.  it pull out easy just wont stay out to kick it over .kicks over and starts no problem
      first post
      josh ohio
    • By Dezertrider65
      I just have a question.
      If I was to buy 3 Wheeler from a private party say a 1985 Honda 350 can I get it made street legal and if not can I still ride it out in the Arizona deserts?
    • By Wonderwoman
      I am hoping that someone here can give me some more ideas. Our poor old red 300 won't start. We rode it, running fine, shut it off and now it won't start. Have gas to the carb and spark at the plug. Valves are adjusted. Still won't start. Tried a little starting fluid in the air chamber and still won't start. This poor old machine has 7000 miles on it. That has to be an Arctic Cat record! And I have never touched the engine besides setting the valves. Unfortunatly it looks like it only has 60 psi of compression. Don't understand how it could be running fine and then nothing. Someone give me a clue as to what I am missing or what to check. I was going to rebuild the top end this next spring but didn't want to do that this winter in a non-heated garage. Any help?
    • By Sblt80
      Lt 80 had new top end rebuild and will not start now,
      I have a spark and compression
      even tried putting fuel down the barrel but still nothing.
      hasn’t even tried to start or back fire since rebuild
      can anyone help please
