• Similar Content
    • By quadmaniac
      I was googling something and started to think about the word "QUAD" and how it's used. Is an ATV a QUAD? We used to call it "quad riding" with my friends and not "ATV riding". I think over in the UK they call it "Quad Biking" from what I can tell. So what actually falls under the term "QUAD"? Do side by sides and UTV fall under this and do they fall under UTV as well?
      I'm interested to hear what people think about this here at QUADCRAZY.
    • By NHPROEQUIP
      5 YEAR WARRANTY ON STRUCTURE
      2 YEAR WARRANTY ON HYDRAULICS
      *FREE SHIPPING   * 1. Free Shipping to Commercial Location with means to offload.
      * 2. Home Deliveries: We still pay the shipping, but customer is responsible for home delivery charges.
        Air/Hydraulic control unit
      2,500 lb Capacity Lift with Maximum Lift Height: 48"
      4 Piece Side Extension Kit, expanding the lift table to 60" wide
      40" Detachable Drive-On Loading Ramp Set (3) features low angle to protect vehicles and stays positioned on the ground when lift is raised, easily moved aside
      Adhesive Back Grip Strips for Loading Ramps Drop Panel for Rear Tire Change Rubber Lined Wheel Vise Super Heavy-Duty Hydraulic Cylinder Assembly
      High Quality and Dependable Locking Mechanism
      Extra Wide Roller Bearings in Scissor Mechanism Smooth Finish Table Top for Easy Cleanup   Work Table has multiple welded cross members underneath to support the heaviest of vehicles Equally Spaced Holes on Table Edges to Accept Tie Downs 9 Position Safety Locking System secures lift in place while working, max height 48"
      Grease zerks on X frame maintains smooth operation
      Powder Coated Finish for durability
            PRO 2500 48" High Rise Air/Hydraulic Lift Specifications:
      Weight Capacity: 2500 lbs.
      Method of Lift: Air/ Hydraulic
      Power Unit: Air Control unit
      Full Raised Height: 48"
      Low Height: 7.87"
      Metal Thickness: 11 gauge steel
      Table Length With 40" Loading Ramp: 133"
      Table Width without Sides: 29.5"
      Table Width with Sides: 60"
      Loading Ramps: Main ramp 40"L x 29 1/2"W (1), side ramps 40" L x 15 1/4" W (2)
      9 Locking Positions: 22 3/7", 27 1/6", 31", 34 1/4, 37", 39 1/2", 41 3/4", 43 3/4", 45 2/3"
      Lift, Air Control, Wheel Vise, and X Wide Side Extensions Weight: 1043 lbs. (4 separate packages)
      Call 603-234-2612
      VISIT https://www.nhproequip.com/pro-2500-48-high-rise-air-utv-motorcycle-lift
    • By lockey
      I need a wiring diagram for a loncin 250  2 cylinder it's a clone of a Honda rebel
    • By lockey
