  • Similar Topics
    • By David Miller
      Does anyone know how to access the check engine codes on a 2018 450 sportsman. Just changed battery and spark plug . It runs fine but the light is on and I need this to plow snow and need it reliable. Any ideas . Thanks
    • By Tahj
      I am looking to see why my 2005 Grizzly  660 won't crank. I have set the valves but suspect a loose timing chain.
      When working to remove the valve cover I found a "cap tensioner case" - parts #25  - #299 on Babbitts site.
      The  cover seems to bridge the valve cover and the cylinder head. What the hell is it and what surprises will I  find if I remove it?
      Uncharted territory for me.
    • By Tahj
      I bought a "project" Grizzly 660, I think it has been a few people's project. The PO had it for a while and did not have time to work on it. He said the battery was good, but I don't know how he knew because the display was blank, no lights and won't crank or run.
      I found a nest under the front cover, by the CVT inlet, a chewed thru wire and a few more without insulation. Rewired those from the connector (black 3 wire to the display) and replaced the fuse as suggested by a search from this site. That got the display working and power to other circuits.
      I replaced the aftermarket start switch with a used OEM switch from eBay. Then it would crank a little, and started once for a few seconds.
      I'm a small engine mechanic - mowers, snow blowers, etc. In my small engine work I have had a number of rider mowers that would crank about a half turn and then stop. The owners have suspected a bad battery and changed it with no improvement. Setting the valves to spec usually fixed this.
      I set the valves on the Grizzly without solving the crank problem. I wonder if the timing chain could be off - slipped a tooth.
      I don't know any way to check for this without pulling the head and looking at the timing marks on the cam gear.
      Is there another way to check for proper timing?
    • By fede hanssen
      Hi all,
      I have just got a 1995 Bayou 220 from my brother. It is in decent condition ant it has not been used much, yet it has been sitting idle for a long time (4+ years).
      The plan is to overhaul it and move it to a location where it will be used 4-6 times a year, so, beyond having the battery charged, the idea is to have it ready and in good condition. It will be stored in a steltered place while waiting to be used.
      My questions would be: 1. What things should I carry out as basic overhaul tasks / 2. What are the typical aches, things to watch out for in this model/year.
      I definitely plan on changing all the fluids, filters,  battery, cleaning the carb, etc. but any specific recommendation from your experience will be of great help.
      thanks in advance!
  • Similar Tagged Content
