  • Join Today, It's Simple and FREE!
scooter2499
honda rancher 400 at boging and smoke a bit
I have a 2007 honda rancher that bog down the other day and smoke a little after but now runs ok . What could it be . It has 97 compression and it only smoke a little while .
Share this post
Link to post
Have you checked the air box? Ive had a similiar expierience with a mouse nest.
Share this post
Link to post
You might have oil going over the seal. That happened to me. Every time i would jump i would have crazy smoke. But it wouldn't ever smoke any other time. Will it smoke just randomly or is it consistent at all.
Share this post
Link to post
A fabulous Gift for all occasions these scrumptious Cakes which spreads love and happiness among your close ones with its beauty and style. Send Cakes to Hyderabad through various online shopping portals and make your loved ones residing in Hyderabad crave for more.
Share this post
Link to post
  • Similar Topics
    • By Tiffany Rowland
      I recently purchased an 07 Honda sportrax and when I was checking the spark plug I saw the boot was ripped nearly in half. When I removed the plug it was blackened and covered in oil. How can I thoroughly clean the plug hole and remove any debris that is in there? Is there a small tube like vacuum or something of the sort made for stuff like this? The machine my dentist has would be perfect, maybe they do rentals! 😁
      I am working on a Honda sportrax I just got my daughter for get birthday and the reverse and neutral light are not working. When I traced the wire down I saw that it wasn't plugged in but I don't see where it is supposed to connect. Does any one have a general idea of where I should look?
    • By Jonathan Foster
      I have a 185 ATC that I’m in the process of rebuilding. Do you guys know anywhere I can find parts or motor specs. I need stuff like shifter seal, head gasket, rings, shocks, and front brakes
    • By Mike Iadonixi
      Hi my son's 2005 Honda recon engine is seized any ideas on what or where to get another engine
      Thanks to you guys i fixed my other son's four wheeler last month
      any help would be greatly appreciated
      Mike
  • Similar Tagged Content
    • By Wali
      I was riding my 400ex one day and when i shut it off to put it in the garage i tried to start it put again to drive it into the garge and it wouldnt start.I put a compression tester on it and its like 30 psi with out throttle and 0 psi WITH THROTTLE.
      when i put my finger over the hole it fell likes its pulling my finger in more then its pushing it out
      Has good spark.When i took it into the shop the said it had 1oz of oil in it and a tiny pit of metal shaving(TINY BIT LIKE 30 flakes)
      When i try to pull start (push start/roll start) it made a not normal sound  and wouldnt stay running.
      If my bottom end is blow why would it still turn over fine,
      Are my valves siezed or not working properly
      or is my timing off causeing valves to not open in correct order with fire
      PLEASE HELP all help is appreciated
    • By Hunter Aldridge
      Some times I get spark some times not can ride then it just dies and wont get spark it has new cdi box and stator but I don't know if it has the pickup coil I'm at a loss
    • By William Sims
      I have a 400 4by4 ,2005 green model,
      wounding how many different CDI boxes will work on it
    • By jerry houston
      Eiger 400 Suzuki runs fine Cook-Out joke face off the handlebars put it back on and will not start now will crank no no spark
    • By colin james
      View File 2012-2014 Polaris Sportsman 400 HD Service Manual
      This the factory service manual for the 2012- 2014 sportsman 400 hd service manual
      Submitter colin james Submitted 02/08/2019 Category Polaris ATV
