trying to get starter out
By HoldenBoy
By crankin
By Asand211
By umax33
where is the starter and solenoid located on a 1985 honda trx 125, is it under the front cover?
By Gwbarm
IMG_4910.mov There is some slack in there but most is taken up by the gear cover,if anyone with history with these machines has had the same problem, let me know your findings. Where i am now im looking for finding replacement honda gears on Ebay and try those. I suspect the original was replaced with aftermarket gears years ago and they just worse quality as the years go by.
