87 Suzuki LT300e Rear Drum Stuck
Go to solution Solved by Jd101506,
Hi all! I’ve got a barn find LT300 with a frozen rear drum. I’ve just about done everything to get this thing off aside from a torch. I don’t have access to the service manual as yet but I assume there isn’t a locking screw somewhere?
I hammered it. I pulled on it. I pryed on it. I soaked it in PB blaster. It’s just about done me in. I soaked it good and put a little pressure on it with my jaw puller to see if it loosens up overnight. Again, this bike was a barn find so I’m not entirely shocked but I wanna be sure there isn’t something I missed.
thanks!
Update: Still stuck after sitting all night with some PB blaster.  I'm trying not to hurt it, but again, I want to be sure there isnt a bolt/nut holding this drum in place somewhere?  I didnt see one, but since I can't turn the drum I can't see the entire surface inside.
  • Solution
Update again and solved. (Mods didn’t approve my post until I solved it. )
shims on the shoes were completely stuck to the inside of the drum. Managed to unstick with some time, PB blaster, and a little help from my friendly map torch.
managed to also rescue the cam actuator for the brakes. I thought for sure it was done for but man the map torch came through again.
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
