Motorcycle Gif Animations and MotoGP Memes
    • By DrtyGrlKristin
    • By Uglyside38
      Anyone have experience using Meier aftermarket plastics? OEM ones are shot on my quad I'm restoring and I have them "Frankenstein'd" for now...🤦🏼‍♂️😬
      Just curious on opinions on Meier as that seems to be the only place I can find any type of replacements. (And they're pretty pricey!)
    • By Params_sweden
      Hi!
      I got my KLF300 running again with your help a couple of months ago, at that time it was the ignition coil that had failed. It has been in use since then without issues until two weeks ago.
      When the new issue showed I was going at about 10km/h and it suddenly slowed to a halt. I started it again after that with choke and I drove it 400 meters and parked. Next time it was really hard to start, and since it was low on gas I thought that was the problem. It didn't get any better with a full tank, so I assumed it was the cold weather, and adjusted the pilot slightly.
      After that it I actually got it started again with full choke and some slight gas, I drove about 300 meters and then it slowed down to a halt again. After that, it hasn't started again.
      The compression is 165psi. The spark has good intensity, the ATV has functioned before with the same spark "intensity"/light. I *assume* that it has gas as well, there is definitely gas on the spark plug when I remove it
      I have checked the carburetor slightly, the float works, diaphragm looks ok, but I haven't disassembled it to really look for dust and such in all the small places.
      My theory right now is that it might've been some dust in the gas tank that went into the system, it's just a theory
      I'm thankful for all the help and pointers I can get, don't hesitate
      / Pär, Sweden
      It seems every ATV i look at to buy used has no title, does everyone loose there title, or do they change hands so often the title is lost in the shuffle. The ones that do have titles are triple the price. I am new to buying used quads is this pretty standard procedure.
      I know all quads are good and tough but thought it might be good to hear opinions as to what member think is the best, from your experiences.
    • By lenoxc
      SO is this website mainly for help with atvs and stuff?
