Following are some rough guidelines to help establish a maintenance schedule for your 2-stroke ATV.
Recommendations are for a High Performance 2-Stroke ATV engines
TOP END: It is recommended to remove your ATV’s top end (cylinder, head and piston)every 30 to 50 hours, most engines will run to 50 hours under normal conditions, but have started to loose their edge on performance in the 25 to 30 hour range. (NOTE: It takes a good running ATV approximately 24 hours to complete the Baja 1000) While disassembled piston to cylinder wall clearance should be checked and serviced accordingly (clearances needed to be measured by a trained professional with the proper equipment). Reeds should be checked and replaced if worn.
New gaskets and top end bearing should be used upon reassembly.
CARBURETOR: Carburetor should be cleaned at least once per riding season. Ideally it is recommended to thoroughly disassemble and clean your carburetor when servicing the top end.
AIR CLEANER: For machines running with air box lid off, air cleaner should be replaced with a clean unit or washed and oiled after each full day of riding. (See DRI Air Cleaner TECH Sheet)
TRANSMSIION OIL: Transmission oil should be changed every 10 hours. When changing the oil warm engine up to operating temperature before removing drain plug. (The oil is drained when hot to help collect any foreign debris floating through your engine) Be Careful Not to Burn Yourself!
It is always a good idea to drain your oil into a clean dry container, so you may inspect it for foreign debris after it settles.
Make sure that aluminum crush washer on drain plug is replaced at least every third oil change.
COOLANT: Coolant/water solution should be replaced each time the top end is serviced.
CLUTCH: When inspecting clutch, fiber and steel plates, clutch basket, inner hub and pressure plate should be checked.
Racing engines should have clutch checked every 25 hours for MX and XC. Every 5-10 hours for TT and Flat Track. Every 50 hours for Desert.
Recreational engines should have clutch components checked every 75 hours of normal riding. For extreme usage check every 50 hours.
Regularly changing the transmission oil will prolong clutch life.
LOWER END: Lower end inspection consists of crankshaft, bearings and transmission inspection.
Racing engines should have engines lower end disassembled and inspected every 50 hours. Recreational engines should have lower ends disassembled and inspected every 150 to 200 hours.
SPECIAL NOTE: Make sure swing arm pivot bolt and associated bearings, bushing and collars must be kept clean and properly greased. Failure to keep this very important bolt serviced can cause bolt to seize in the swing arm. Causing expensive damage to repair.
      I have noticed lately that the ATV tires i generally buy have upped in price quite a bit. The Kenda EX that i generally get are sold out and not available at this time, the EVO which is usually my second choice has increased 50.00 on a set of 4. The HTR Kendas best tire is now 150.00 per tire. Even the Sun F have increased but not so much as the others.
    • By Atomusthenes
