Looking for someone reasonable and experienced to do a engine rebuild yamaha
By HSTAR
By ResQ91
Hi guys
battery and connections good
By utvboard
2009 HONDA BIG RED
Big Red
KEY FEATURES
2009 Honda Big Red in Camo
By McG75
Sorry I suck at these forums so if you see this submitted under update status, my bad. Anyhow this is a new shock for a 96 Yamaha Kodiak 400 4x4 it fits my 96 Yamaha Timberwolf 250 4x4 perfectly. Little narrower are the bottom than the original but everything else is perfect. I extended it to almost a half in from full extension because I’m pushing 350 pounds. It rides and hold me well. So if any of y'allRace driven shock. have been looking for one and didn’t want to do the research here it is.
By John Sinclair
I WANTED TO UPGRADE THE CARBURATOR ON MY 1992 BIG BEAR 350, SO I ORDERED A NEW CARB FROM EBAY. ACCORDING TO THE WRITE-UP IT WAS A GOOD FIT FOR BIG BEARS FROM 1988 TO 1996. WHEN I REMOVED MY ORIGINAL CARB I NOTICED THAT IT WAS DIFFERENT FROM THE NEW CARB MY CARB HAD TWO THROTTLE CABLES THE NEW CARB ONLY HAD ONE CABLE. HOW CAN I MAKE THIS CARB WORK ON MY TWO CABLE THROTTLE?
