By PupATV
-PupATV
By bhristianzx12
By jhamrick75
By cameronokeefe6
I have owned my 84 Honda 200m for years now and I am wanting to see what i could do to upgrade horsepower , speed , performance , power etc and do it safely and not cause future harm to the engine.
I was thinking on getting a 200x piston, will this work and give a good power increase ? I have heard people have done this in the past and it works great. and i was also thinking on a 200x cam , will the 200x cam fit in this engine and make a difference also does it require the upgrading of any other parts and will i have to run 91 octane instead of 87 ? has anybody run this setup before and got good results ?
I was also gonna go with a 200x carb but not sure if i have to buy an intake to hook it up or will it just bolt onto the 200m intake and fit fine ?
If anyone has any suggestions and advice on what i could do it would be greatly appreciated ! thanks in advance.
By Werewolf
