Hi I have a 2005 yamaha 400 big bear. When I run it without the breather cover on it runs good. This is without the air filter. As soon as I put the lid on and snap it down tight I have no middle or high rpm. Any ideas. I've checked the pipes from the air breather and all are clear. No animals nesting in them.
The behavior you're describing sounds like the jetting is rich. When you cleaned the carb, did you use any hard objects to clean out passages?
Sent from my KFOT using Tapatalk
Shifter shaft was broken so it sat for awhile. So with it sitting so long I figured I would clean the carb when I received the new shifter shaft and installed it. I noticed the intake rubber manifold is hard now with some tiny cracks. I'm guessing it's starting to get old.
    • By cfherrman
    • By mehim
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
