Hey guys! I made an account hoping all of you could help me diagnose a problem with this LTR I'm looking at on ksl.
"it runs well when it starts, although takes a minute or two of staying on the throttle a little bit to get it to idle on its own when it is started cold It'll idle once it warms up. It'll even start on it's own when it's warmed up"
that is how the owner described it to me over text. I'll be checking it out Saturday morning. Any advice on what to look for? He is asking $2,400 everything is stock besides an aftermarket air filter. Here's the ad
2006 Suzuki LTR 450 -- SALE IS PENDING
http://www.ksl.com/index.php?nid=218&ad=45163237
I took a quick  look at a review  of that  quad.  Since it is  fuel  injected there   should  be  a fuel  enrichening signal  while the  motor  is  cold . My  guess would be  either   a sensor  is not working to  give it  the signal,  or  possibly  because the  quad  is designed   principally for racing   it doesn't  have that feature .. Having  to  give it a  little throttle  until  it warms  up   is  no  biggie  to  me.  If you're  looking  at  the  quad  more  as a trail  rider  than  a racer,  be  aware that it has  no reverse..   You  need  to  manhandle it  back  if  you get  in a sticky  spot..  That  to  me  would be  a deal  killer since  I  am  not  a racer,  and I  definitely  need to  back  up  quite regularly.
    • By HoldenBoy
    • By ButchM
    • By dkgg5755
    • By BillR94
      Thank you for your time
      Bill
    • By kx9m
      Retired carpenter here looking for things to do... What else??  Work on old quads sounds good!!
      Here for manuals and advice..
