Is there a magnet on the outside of the rotor/flywheel that works in conjunction with the pick up coil.  Or is it a different type of metal that changes the impedance to have the pickup coil do it's thing?  I'd assume that most othe Yamaha's use a similar operation.  Thanks,  Don't see anything about it in the service manual.  Don't see anyway to adjust the gap between the pickup coil and the flywheel.
    • By jen
      Dragging a magnet behind my ATV when going through the woods.
    • By anthonyd256
    • By JPRICE1981
      Hello everyone !! Looking for some help !! Im wanting to check my stator and pick up coil with a ohm meter and cant seem to find a guide that tells me what to read and what my reading should be !! Any help would be great !! THANKS IN ADVANCE !!
    • By WHALErn
      I ordered an ATV through ElectriRide a ( Pioneer 1500w Power E-Grizzly Electric ATV ), on February 13, 2024.  They ( ElectriRide ), ordered it from the manufacture on February 28, 2024. Not sure when it shipped, but it arrive here at my house on June 25, 2024.  I live in Hawaii.
      Unpacking it, I quickly became aware that this was not the ATV that I ordered.  The package had some damaged, but not major.  After unpacking it, it was very obvious that this was not the ATV that I had ordered, plus it was missing some a number of parts, namely the rear rack & no instruction or electrical circuit layout, just to name a few.  A couple of days later I found ( 2 ) small two burnt holes in the upper frame, right side, also.  Several days later I tried to charge the batteries on the ATV, after plugging it in for over 4  hours, “NO CHARGE” , I checked the charger’s output voltage, it read “ “ 0 “ volts, the charger needs to be replaced also.
      The next day, I reported all of this to ElectriRide, & they asked for photos, which I later that day send to them.  They said they would look into it and get back to me. For the last 2 1/2 weeks, I have been calling them (playing phone tag ) & emailing them, basically getting the same message back from them.  They sent me e-mails “ we will get back to you “ or “ Please rest assured that we are committed to resolving this matter to your satisfaction. “.  As of today, that message was 10 day ago, and it’s been 3 weeks after receiving the wrong ATV.  And 5 months from the time of ordering the ATV.
      The ATV that this looks the most similar/closest to the one that I received is the ( Pioneer 48v 1000w Adult ATV Electric ) in their catalog, but there are a number of differences to it also.  ( Mostly it’s a 1000 watts motor, not a 1500 watts motor ATV, plus a number of other things also ).  The suspension & wheels are completely different, along with some of the electrical components, and it was missing the rear rack also.  Along with some other minor things.
      I seem to be getting nowhere with communicating with them, (ElectriRide ) in getting this mix-up / changes resolved after calling / emailing them pretty much daily for over 3+ weeks, I am turning to you, the ATV community for any suggestions for helping me to solve my problem.
      Please leave any suggestion / ideas, you thing might help me solve this problem, or who to contact that might be able to help..
