Hello Folks....new to the forum.  I have two Warriors (87 and 92), and an 89 Big Bear.  Looking for some help with engine issues on the warrior, and my 89 Big bear backfired and died. Got spark, got gas, seems to have compression, (but haven't tested it yet...next). She rolls over good, maybe too good...seems soft. Have spark and enough compression to blow gas mist out the plug hole when cranking. Suggestions, Been running great since we got it.
You need to get the compression reading and go from there. It could be a valve stuck open a bit and not closing all the way or something worse (hope not).  You say it rolls over good so I assume you mean it cranks fast which sounds like low compression for what ever reason.
    • By RGS
    • By RadRob
    • By Thumpinhard25
