Wont go in high gear but will all other gears
By buriedpast
By hurnyak
What is the best way to remove the carb on a 2000 quadmaster 500? Does the gas tank need to come off first?
By Joeguy
Did a top end rebuild, honed .010 over, new piston, rings, valve seals, etc. When i re assembled i only had like 30 psi of compression but then after it sat all night i now it seems to have gained some somehow, there is much more resistance pulling it over and i even got it to fire for a few pops. Issue i got is that it makes a loud squeak noise through the intake i believe (goes away when throttled so something with carb area) and it seems to not want to run well. I took head cover back off and timing seems fine so im not sure if something is sticky and that's why i got some change over time or maybe the valve lash is messed up after doing all this, i did get another cam for it but i wouldnt think it would make enough difference to need to re lash. Any insight on next step would be appreciated, i will be looking up how to do lash on these because it is a very weird angle to slip a feeler gauge in.
Actually cam is slightly off now that i look at the picture, thought it was good while looking in person. Hmm.
By Ejwill
By JustCrazyNoQuadNeeded
'Gidday. An issue I can't find discussed already - my Bear Tracker selects into 1st gear fine. Selects other forward gears fine too but all above 1st gear are slipping. Can select reverse but nothing engages/happens.
Any ideas what I might be dealing with?
Cheers, Jim.
