I am looking into purchasing a new quad/ATV. It will mainly be used in the Precambrian Shield/Boreal Forest (northern Saskatchewan) for exploration work. I will be making my own trails, weaving around and over trees, in low-range. And then when I get from point A to B, I will probably drive back to point A and then tow a small trailer back to point B. I will probably have a passenger when doing this.
A couple of options that I have been looking at are the 2026 Can-Am Outlander Max Pro XU and the 2026 Honda Rubicon 520 DCT Deluxe. One is larger than the other and they both have different types of transmissions.
If any of you have had experience creeping around the forest with either these two machines or something similar I would like to know which one you would choose over the other and why.
Is one transmission going to jumpier than the other, taking into consideration that I will be driving in low range?
Will one have a better turning radius?
Will they stay cool at low speed?
Since I am not using it for trail riding, should I be looking at taller and/or wider tires for creeping around the bush?
Your comments are much appreciated.
Thanks.
Edited by ScottK
    • By jay41198
    • By mehim
    • By logray
      Hi all,
